01-07-2008, 11:21 AM | #1 | ||
Is it possible to put BA into AU front seats without to many drama's? Anybody done this?
FGII XR6 IN LIGHTNING STRIKE R52 SIII IN GUN METALLIC |
01-07-2008, 12:06 PM | #2 | ||
The Monty
i was wondering in the same, also if you can put back seats in aswell
01-07-2008, 12:13 PM | #3 | ||
[ON DUBS]
I've tried it.
Front is easy, rear is not possible due to the difference in design. BUT i tried it in my fairlane. If the fairlane rear seat is exactly the same shape as falcon based models then no you won't fit a BA seat in. |
01-07-2008, 02:31 PM | #4 | ||
not here much anymore
Fairlane rear seat is wider
This can be done but you need to have the rails changed so the BA seat is on AU rails
2024 F150 XLT
01-07-2008, 02:48 PM | #5 | ||||
Back to Le Frenchy
01-07-2008, 02:49 PM | #6 | |||
So is it possible to swap the rails straight over between seats
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
01-07-2008, 02:53 PM | #7 | |||
2024 F150 XLT
01-07-2008, 02:54 PM | #8 | ||
THE Fairmont Ghia 75th
its a weld job for the ba seats, not an impossible task if your not a bad welder, mate did it in his au but the welds were shockin,lol
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install. My Ride My Build Thread |
01-07-2008, 02:59 PM | #9 | |||
Do u think u could get photo's on the mods to the rails so we could have a look at how they need to be modified
01-07-2008, 10:02 PM | #10 | ||
so the fronts are easy? its only the rear thats hard?
01-07-2008, 10:36 PM | #11 | ||
www.TUFFCARPARTS.com
Bomber did BA XR seats in his AU XR6. As has already been said, it required welding.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
02-07-2008, 06:50 PM | #12 | ||
Next upgraded Mk1 Leopard
Yeah the wreckers out at Macarthur Parts Plus in NSW said no swap, nothing lines up re bolts etc.
I'd be worried insurance if you had BA's welded onto AU rails. UK
02-07-2008, 08:00 PM | #13 | ||
you only need an engineers certificate to say its done properly which then makes it fine for insurance purposes.
and the cert is only required IF you modify or swap out the standard rails if your new seat bolts onto the old rails then your sweet to go
