19-05-2008, 07:51 PM | #1 | ||
mezzo forte
Hey guys
Departed work today, and noticed in slow maneuvers around the rough car park and speed bumps, a loud squeaking every time the front left wheel went up/down. Didn't notice it on the open road, but at home on the driveway etc it was very noticeable. The car didn't seem to perform any differently on the road. I gave it the good ol' shock test by pushing down the front quarter but it seemed fine, except for the loud squeak. Been doing a lot of driving on wet dirt roads recently, don't know if some grit got somewhere it shouldn't. Anybody have any ideas as to the noise source? Btw I have King ultralows around stock shocks, don't know how old the shocks are either, probably original kit. Car is forte sedan with 156k on the clock. Cheers, Nic |
19-05-2008, 09:02 PM | #2 | ||
sway bar bushes. a lot of people have had these issues recently, all seem to be the same cause, these wouldn't show up as easily just bouncing the car up and down, only under a lot of movement
19-05-2008, 09:44 PM | #3 | ||
Sly like a G6
A seized upper control arm ball joint can also make a squeaking noise if changing the sway bar bushes doesn't fix it.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
19-05-2008, 10:04 PM | #4 | ||
mezzo forte
Hmmm i might get under and have a look, hit em up with some wd40 lol. Or maybe time to upgrade to nothalane
Cheers fellas |
20-05-2008, 12:51 AM | #5 | |||
Walking with God
GK
20-05-2008, 03:46 AM | #6 | ||
FGII XR6, Focus Sport, XR
It can be a few different bushes. Sway bar, upper control arm bushes(which are hard to get to with lube) or even lower control arm bushes. maybe even the spring rubbers. I wouldn't be pointing at the ball joints. Maybe after checking everything else.
I'd say lube up the easiest to get to bushes then if the noise is still there do the other bushes that you can lube without having to press any out. Hope this helps. Cheers
Living Ford dreams
2011 Purple FGII XR6 2016 LZ Focus Sport BA XR8 Build Thread (SOLD) 1966 XR Falcon Build Thread |
