Old 12-01-2008, 10:30 PM   #1
bj54
Exclamation au door locks actuators
does anybody know if the plastic gears in the door lock actuators are the same size in the front doors and back doors (interchangeable)
bj54 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2008, 10:35 PM   #2
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF events and sponsorship. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Everything you do to help this place run smoothly! Technical Contributor: For members who share their technical expertise. - Issue reason: The awesome Technical and Service how to's in the FPV /XR6 /G6ET turbo threads..  and his own build threads that inspire people to have a go... enabling people to save money and realise the dream of working on their own cars as well.
Yes all plastic gears are the same.
Check this from our Technical Resources
http://www.fordforums.com.au/vbporta...article&id=320
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED
2017 GT Mustang Plenty of RWKW
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2008, 11:47 PM   #3
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
I thought it best to bring up an old thread of the same topic than create a new one, as i have similar issues and need some advice...
For a start... I cannot use my remote locking... just flashes all over the place... unlocks the doors in this fashion: press once, drivers door unlocks... press 2nd time, the rest of the doors unlock... press a third time to lock... and the acuators go nuts followed by the blinkers going on and off and the horn beeping a few times... but does not lock the doors...
2nd problem... everytime i open and close any doors, all the actuators go nuts a couple of times...
3rd problem... my front passenger door decided it didnt want to lock anymore... so for safety and security... i disconnected the acuator and the outer door handle...
any suggestions? i will be using the above tutorial guide for any drive shaft breakages... but unsure about the rest...
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2008, 12:13 AM   #4
SpoolMan
SpoolMan's Avatar
Fix your 3rd problem 1st you will find most likely this is the cause of all your problems.
I had a rear door that wouldn't lock on my AU the actuator was broken, car wouldn't lock and sometimes it would lock, in general it was playing up, once l replaced the the broken actuator the locking system started to work normal again.
[SIGPIC][/SIGPIC]
Old 18-05-2008, 07:41 AM   #5
InfernoSR
InfernoSR's Avatar
Well i just realised a little mistake in how i worded my information... i meant to add with the 3rd problem that it happened after the other issues... it was ok when i bought the car... and using the key only, i could centrally open and close the doors... problem 2 still existed though...
Old 18-05-2008, 12:04 PM   #6
SpoolMan
SpoolMan's Avatar
that's probably because you now have more than one door actuator broken...
[SIGPIC][/SIGPIC]
Old 18-05-2008, 05:09 PM   #7
InfernoSR
InfernoSR's Avatar
Until recently all doors locked and unlocked at the same time though... thats what i meant...
