16-05-2008, 08:05 PM | #1 | ||
BA Mk2 Fairmont
My stereo control on the steering wheel is stuffing up and I want change them. Will a second hand one from ebay/wreckers work? Do I need to code them or anything?
But more importantly how do I remove the old one and install a new one? Cheers |
16-05-2008, 08:51 PM | #2 | |||||
All Bran = Regular Member
JC's post here: http://tinyurl.com/5hrlao will get you underway for airbag removal. Good luck with it. |
16-05-2008, 08:55 PM | #3 | ||
Dent Removal
How are they stuffing up? it may be the clockspring causing the problem
16-05-2008, 09:06 PM | #4 | ||
Casual surfer
Most likely problem is the ribbon cable connecting the switches in the wheel to the column, this happened in my AU, from memory about $125 from ford for the replacement, be careful not to pull the pin when installing or it will all come unwound. you will need to remove the air bag and wheel to get to this part
GTF-#97-Kinetic/Matte Black, Manual, Enjoying it daily Sold- 08 FG XR8 Sed EGO, 6 speed m, 80mm John Bowe throttle body, K&N air filter, Big Mouth CAI, rip shifter. 275/30-19,245/35-19, XR50 Sold- 06 BF XR8 Ute, 6 speed,80mm throttle body,Herrod full stainless cats back,K&N air filter,CAI,rip shifter.265/35,245/40-18. Sold-Mrs Jase_Boss-09 XR8 Sed Breeze-Build to order for her,All options except sat nav,6 speed m, 80mm John Bowe throttle body, K&N air filter, Big Mouth CAI. 19" |
16-05-2008, 10:29 PM | #5 | ||
BA Mk2 Fairmont
The Vol + button doesnt work properly. Sometimes it works sometimes it doesnt. So I took out the plastic bits but while taking them out they snapped. I super glued them back and tried putting it back in but they keep snapped again. I might just go to the wreckers and hopefully buy the plastic bits because its going to be a pain removing the steering wheel.
But how on earth do I get the plastic bits in and out without snapping them? |
17-05-2008, 11:37 AM | #6 | ||
BA Mk2 Fairmont
Just another question the EF/EL control are the same arent they?
