Old 24-03-2008, 03:55 PM   #1
paddy351
Ford Nut
paddy351's Avatar
Default sticky tyres
I have an xw and i run a 15 x 8.5 rim with a 265x50x15 tyre , i runa 50 series to stop scraping as i run a std 9 inch. I was thinking a micky tompson but i would like to keep the same size tyre , whats out there. thanks
paddy351 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2008, 05:41 PM   #2
SPK-250
SPK-250's Avatar
265/50-15's MT ET Street Radials. Or even something like a Hankook or Kelly with that Silica BS! They are some sticky tires those silica ones.
What would forum's be without post whoring know it all's.........
SPK-250 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2008, 10:12 PM   #3
DBL15
love being blown
DBL15's Avatar
i take it you want to be able to drive to the track on them?
if so then yeh M/T's streets is what i use and just heat them up good and away you go
if not driving there and your on a trailer look for a full slick for more grip but watch your drive line
GT-P 2003 + XR8 Supercharged Ute 260+ BOSS : : :sm_headba :
New PB 12.4 @ 108mph : :
www.xrclub.com.au
DBL15 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2008, 11:24 PM   #4
paddy351
Ford Nut
paddy351's Avatar
i had a look at the m\t website and i found 26x10.00x15 in either sportsman or S\R's . i am guessing the S/R,s are softer and are more for circuit and sportsman's are more straight line tyres.
Old 25-03-2008, 04:17 PM   #5
DBL15
love being blown
DBL15's Avatar
i dont beleive sportsman range are DOT approved are they? meaning there fine for a car on a trailer but not street use is this correct?
www.xrclub.com.au
Old 25-03-2008, 04:22 PM   #6
protd
TUFF FORDS
protd's Avatar
no DOT tyre is legal on the street in AUS that is the US street legal tyre..
i have had many tickets over the years for running M/T DOT street tyres
protd is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 05:01 PM   #7
paddy351
Ford Nut
paddy351's Avatar
yes the sportman are D.O.T but the sportsman s/r are radials don't seem to be D.O.T tyres so they might be the go. 265x50x15 ssem to be only avaliable in yokies , has anyone tryed these ?
Old 25-03-2008, 09:13 PM   #8
DBL15
love being blown
DBL15's Avatar
wow i never new that hmm well thats got me thinking then : :
because i run them on the way to the drags etc never been done yet
www.xrclub.com.au
Old 01-04-2008, 02:28 PM   #9
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
I've go them on mine when not at the strip. Yoki 352's. They've been around for years and look great and are quite a durable street tyre....but for drag racing you'll spin the crappers out of them compared to the MT's.
As best as I tried with my last mild engine, I couldn't get a 60ft lower than 2.2 with the Yokies. That's with 4.11's and a toploader......just too much gearing.
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2008, 09:20 PM   #10
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
These look quite good too:
http://www.intercotire.com/site50.php
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2008, 09:32 PM   #11
Crapi
I run the M/T ET Street Radials, pretty sure they are legal in Aust.
You will not need to run the same size tyre that you run on the street because they have that much more bite, plus it will cost you less.
For a set of 235/60-15 street radials it will set you back $530-. Go the M/T's nothing else compares! :evil3:
Crapi is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 10:26 AM   #12
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
They arent legal in au,
I and others I know of have been defected for running them,they have no speed or load rating so will never be legal here.
The stickiest 100% legal tyre I have ever used is the toyo RA-1 or R888 tarmac rally/circuit tyre..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2008, 12:55 PM   #13
ClevoCapri
ClevoCapri's Avatar
Im with nugget378. Ive had Toyo proxes RA-1's and there awsome. Definately the best street legal tyre for grip. Cheaper than the bridgstone race spec tyres and warm up faster. The toyo's I had seemed to wear ok aswell.
ClevoCapri is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2008, 12:24 PM   #14
Crapi
Thanks for that info nugget378, i was under the impression that they are "street legal"! That just might save me from the same fate you have suffered.
Any idea what sizes the above mentioned treads come in? And being a cicuit tyre they are probably quite stiff in the way of deflection?
