Old 22-06-2005, 04:54 PM   #1
ferris01
I am a Princess!!!
Default LG LAFINION 76cm TV
Just thought that I would tell everybody that the above TV is what we ended up getting. Unfortunately we are having problems with it. First purchased it last Wednesday 15/06/2005. We were watching the state of origin and during the match it happened about 3 times where it went off for a second came back. When it came on in the top right hand corner it came up (Component 2) then (L+R). Originally we thought it was the reception from the footy. The next night was watching the TV and it did the same thing. Rang the shop on Friday and advised them what had happened and they replaced the TV on Saturday. When the delivery guys turned up on Saturday with the replacement and to take the old one away the guy pick up the wrong power cable with the TV and dragged our DVD player of the cabinet onto the ground. So as you can guess set up the TV and it started doing the same thing. Went to watch a DVD and its not working. On sunday went down to the shop and told them everything that had happened. The mamager said I would have to take the broken DVD issue up with the delivery men. And they would take the TV set it up in the Shop to hopefully replicate the problem at home (Forgot to mention that this TV turned up with scratches on the bottom front panel).
Now today rang the store and they are unable to replicate the problem so they are returning the television tommorrow. When I mentioned the scratches they have said they cannot recall me telling them of Sunday.
So I guess my question is for the people out there is have you encounted this problem before?
We are using it with a HD set top box as well but that is not flickering at all when the TV goes off...
ferris01 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2005, 07:03 PM   #2
Peuty
Afterburner + skids =
Peuty's Avatar
Haven't encountered the problem before, but the Store wouldn't have happened to be Betta or Harvies was it?
Oo\===/oO
Peuty is online now   Reply With Quote Multi-Quote with this Post
Old 22-06-2005, 07:45 PM   #3
ferris01
I am a Princess!!!
No but they have a catchy tune...Na Na Na
Old 22-06-2005, 09:01 PM   #4
Perana
Perana's Avatar
I have got the same television, had it for about 2 months now has no probs at all.
'09 SYII TTG | Mystic
'06 BF XR6 | Mercury Silver
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2005, 10:44 PM   #5
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
argh that tune is awful!!!
take it back and tell them the service isnt good enough and take it uop with them until they replace it i say
chris
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 03:20 AM   #6
FoxMulder
Could it actually be the set top box itself, that is causing the problems. Sometimes our STB will cut out for a second or two, (i.e. the reception will drop out momentarily).
Maybe the STB is dropping the signal a bit?
Does it occur when the video player is hooked up? Have you tried it on regular reception? It would probably be a good idea to try these first, considering that the shop could not find (or admit) the problem.
FoxMulder is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 03:33 AM   #7
MrQuan
Social Disaster
MrQuan's Avatar
When you've haven't got a clean signal, LGs will show the channel (Component 2) and "L+R" to say it has picked up the siganl with stereo sound. Everytime your signal dropps out momentarily, and the TV picks up the signal, it will display this to tell you it found a stereo signal (L + R = left and right sound).
Try getting better reception on your STB.
Also, there *might* be a menu setting somewhere to turn off this message everytime the signal is interupted. My olds have an LG and they get the same messages. (I've never looked into turning it off if possible).
1995 EF Falcon GLi, Auto, 4.0L I6
Mods:
3.73 LSD | Darkest legal tint | tinted back lights | Sprayed Dash | Custom Trims
Sound System:
Fusion front splits, rear 3-ways, and 2 x 12" subs with ctrl, 3 x Fusion amps | Clarion HU | 1F Cap | 60GB Zen Xtra | 800W RMS output!
MrQuan is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 02:25 PM   #8
Perana
Perana's Avatar
Yeah occaisonally the picture goes crap on ours... It due to the Digital signal to the STB dropping out.
Old 23-06-2005, 03:55 PM   #9
BA Bakes
It's Cat huntin season...
BA Bakes's Avatar
I have a same type of TV. Had it for over a year now with no problems. I have recently got a STB and occassional the signal drops for a second or two like other people have said, I just put it down to the crapping receiption I get at home. Good luck with getting it sorted out.
XRB055 - Black BA MkII XR8 Ute.
6 Speed manual, Leather seats, hard lid.
To do list - Cat back exhaust, new wheels, new shock and front sway bar, and whatever else seems like a good idea
Old Ride
XR40RD - Phantom BA XR6
160 rear wheel killer wasps - Pacemakers - 3" HiFlo Cat - 2.5 Redback exhaust - 18" Speedy Graphite Rims - Dumped on King Superlows - Standard ICC with iPod cradle, 5x7" Boston Acoustics, 12 Alpine sub powered by 4 channel Alpine amp
[/SIZE]
BA Bakes is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 06:16 PM   #10
ferris01
I am a Princess!!!
Thanks MrQuan and everyone here...got the TV back today god it has a great picture...
Old 23-06-2005, 06:49 PM   #11
seano14
sounds to me like some wiring inside the tv is shot, like wiring from the component plugs, and the picture is breaking up from that. we have an older lg tv here and that message only shows up if you lose signal from whatever is plugged into the component plugs, ie turning off the ps2 etc. the message pops up then. some dodgy wiring may cause the signal to be interrupted... my best guess anyway
seano14 is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2005, 09:49 PM   #12
Peuty
Peuty's Avatar
No, I tend to agree with the others, your STB os just dropping out due to poor reception. Unlike analogue TV, where if the signal is weak you will get a hazy picture, a set toop box will infact drop right out. I guess what I am trying to say is there is no inbetween with a STB.
Oo\===/oO
Old 23-06-2005, 09:55 PM   #13
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
ah yes the digital cliff effect!!! sux *** dunnit? i cant be 100% sure but that would be a pretty safe bet that its not the telly in this case. i have had problems with the power supply in my telly (lg) but not that.... STB dude.... STB
Originally Posted by AL NZ
it wouldn't matter what FPV or FordOz call it, because it will be - The One.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
