Old 20-11-2007, 02:20 PM   #1
JMO
JMO's Avatar
Default Brake reassembly
I've taken off my calipers for painting, and just wanted to know if i need locktite to secure the bolts when putting them back on.
Thanks.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2007, 03:28 PM   #2
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
No, just do them up well!
MNM96 is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2007, 03:29 PM   #3
Jokular
Jokular's Avatar
I didn't and haven't had any problems yet ,that doesn't mean it's a good idea not to put new loctite on though.
Seriously brakes are one component you don't want coming loose/falling off so I'd say yes put new loctite on.
My Car
Jokular is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2007, 04:12 PM   #4
JMO
JMO's Avatar
There was some yellow residue on the two hardest bolts to get off. According to some of the websites i've read, the 'RED' loctite is the 'high strength' for automotive purposes. According to the site, you need to heat the bolt/loctite to 250C to remove the bolt. If i did put it on, how would i go about heating the bolt up to this temperature?
Old 20-11-2007, 04:36 PM   #5
XR Lita
XR Lita's Avatar
Oxy. It's how we have to pull calipers apart that are siezed.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2007, 05:23 PM   #6
MNM96
MNM96's Avatar
I relined brakes for a living, up to 20 set a day. Do whatever you thinks best but!
Old 20-11-2007, 08:52 PM   #7
mik
mik's Avatar
i use Loctite on my calipers, it takes a bit more muscle to get them undone but have`nt found need for anything more than a strong arm or a bit more leverage, you don`t need to drown the bolts in the stuff though, a couple of drops will do
Old 20-11-2007, 09:37 PM   #8
Eu-GenixX
Eu-GenixX's Avatar
i've never used loctite before.... i've never had a problem...
Eu-GenixX is offline   Reply With Quote Multi-Quote with this Post
