Old 01-11-2007, 04:58 PM   #1
fishit13
Default wheel bearing au
hey all im getting a noise from my au ute im thinking its the wheel bearing when im going in a strate line there is a rumble sort of noise when im going arond a left hand bend the noise is gon ........the steering is all good and feels the same as allways no shudder and smooth as ,,,do you think its the back wheel bearing????? how do i chek if its the back or the front?? :
fishit13 is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2007, 05:00 PM   #2
ronwest
All Bran = Regular Member
More likely front if the noise changes when turning.
Have a look through this and see if it helps.
http://www.fordforums.com.au/vbporta...article&id=319
Old 01-11-2007, 08:49 PM   #3
howesy
howesy's Avatar
Go here , cheap as chips
http://cgi.ebay.com.au/ws/eBayISAPI....MEWA:IT&ih=006
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2007, 09:00 PM   #4
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Check your lower bushes... these can also make noises in straight lines...
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2007, 10:29 PM   #5
waggaclint
waggaclint's Avatar
normally if you drive only a smooth road and swerve from left to right at around 60kph say you should be able to pin/point the noise (ie when turning left if you can hear it then its the r/h one and vise versa)
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2007, 03:24 PM   #6
tonk
i have the same problem mechanic said its my left hand front wheel bearing. is it louder when u turn right? if so it cos of the left hand side is under more load when u turn right.
tonk is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2007, 06:13 PM   #7
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
Ive got sorta same problem mines the rear left. Sort of like a clonking noise and worse wen u turn right. Mechanics diagnosed it.
Current car
94 ED Fairmont 5L in Burgundy
Fords ive owned-
2010 FG XR6 5 speed auto in Mystic
81 XD S-Pac 302c 4sp manual
78 Yellow TE Cortina Wagon 4.1L
92 Green EB Fairmont GT replica
01 Black AU XR8 II Manual
04 Rapid BAII XR6T 220rwkw
04 Mandarin BA XR6T 247rwkw
07 BF II XR6T 385rwkw
1980 ZJ Fairlane 302c
mr302xd is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2007, 09:08 PM   #8
tonk
i changed my left hand front wheel bearings(well hole hub) easy had no problems took 30mins. now its rolls better and is quiet
