View Poll Results: Which Cam?
621317 - Crow - Manual Cam - 9 60.00%
2031 - Crane / Powermax - 6 40.00%
Voters: 15. You may not vote on this poll
Old 12-11-2007, 10:11 AM   #1
james22
With da Warlords
james22's Avatar
Default Which one?
Finally narrowed my cam choice after extensive research. So simply, which do you think would benefit more. I'm after an overall power and torque increase.
Current mods are;
− PH - 4001 Pacemaker Extractors (Tri-Y)
− STD Press Bent 2 -1/4" Exhaust - Single Hi flow Muffler
− BPT Powerstat
− BPT 12mm Phenolic Spacer
− K & N Hi Flow Panel Filter
1. 621317 - Crow
IN.26/64 | DUR 287 | 0.50" DUR- 222 | LIFT .538
EX.66/24 | DUR 279 | 0.50" DUR- 217 | LIFT " "
Medium cam for manual trans.
2. 2031 - Crane / Powermax
Intake @Cam 302 @Valve 513
Exhaust @ Cam 311 @Valve 529
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 0.0 BTDC 34.0 ABDC 107 214 °
Exhaust 47.0 BBDC (7.0) BTDC 117 220 °
Pros and cons for both?
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2007, 02:10 PM   #2
james22
With da Warlords
james22's Avatar
Also another question for AU V8 owners.
Am I correct in assuming that when you connect an oil catch can, you run the pipe from the PCV valve at the rear of the motor to the catch can, then from the catch can back underneath the manifold??? Where the PCV was hooked up to???
Windsor Warlords
AU III XR-8220
Old 12-11-2007, 08:46 PM   #3
RG
Back to Le Frenchy
RG's Avatar
I hooked mine up from the TB to the catch can then from the catch can to the oil filler neck, replacing the hose from the filler neck to the TB. I did it that way because I found most of my oil was collecting in the TB suggesting that is how it was entering my intake.
Old 13-11-2007, 08:50 AM   #4
james22
With da Warlords
james22's Avatar
Well, I'm leaning towards the crow cam. Are the springs and retainers here any good?
http://www.crowcams.com.au/templates...dsor-EFI.shtml
1 x 621317 camshaft
Set of 7738 valve springs (crow)
Set of 11700-XR8 Performance Retainers, 8 std,8 +0.100"
What does this mean?
Heavy Duty Springs (use 11710 ret on Ex.)
Windsor Warlords
AU III XR-8220
Old 13-11-2007, 09:11 PM   #5
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
James , your probably going to get a Stronger answer asking The Site Sponsors .. Just a Suggestion
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2007, 10:25 PM   #6
b2tf
not here much anymore
b2tf's Avatar
yeah right, half of them dont even check their forums for months on end.
James go the Crow and get the parts kit K6201, dont use Crane Valve Springs - heard a few horror stories about them.
2024 F150 XLT
Old 14-11-2007, 12:09 PM   #7
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Yeah mate, run the catch can between oil filler neck and t/b breather.
When the cam is fitted etc, are you going to use a flash tune?
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2007, 12:51 PM   #8
stiddy
stiddy's Avatar
my suggestions.
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,500-6,000
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 232
Duration at 050 inch Lift: 224 int./232 exh.
Advertised Intake Duration: 286
Advertised Exhaust Duration: 294
Advertised Duration: 286 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.542 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.542 int./0.563 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
OR
(Too wild for what your after I think)
Basic Operating RPM Range: 3,200-6,800
Intake Duration at 050 inch Lift: 236
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 236 int./248 exh.
Advertised Intake Duration: 298
Advertised Exhaust Duration: 310
Advertised Duration: 298 int./310 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.574 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.595 in.
Valve Lift with Factory Rocker Arm Ratio: 0.574 int./0.595 exh. lift
Lobe Separation (degrees): 110
stiddy is offline   Reply With Quote Multi-Quote with this Post
