Old 29-10-2007, 05:28 PM   #31
TwistedEL
TwistedEL's Avatar
Originally Posted by partie
Tried it on my TE50, it worked. But took a couple of tries.
The EF/EL instructions are here:
http://www.fordmods.com/forums/documents.php?doc=12
I have tried it successfully from GLi, Fairmont Ghia to DF LTD.
It's very easy on the EF/EL, but can be complicated if you have a police cluster
Not sure why they made it so much harder for the AU
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2007, 06:23 PM   #32
Mechan1k
Mechan1k's Avatar
Have used it many a time .... was trying to diagnose if the PCM and dash were receiving readings from the LPG senders on the tanks ... could see the actual Impedence readings going outside the range during driving ... and then seeing the fuel gauge react at the same time.
Also was testing during my overheating issues with the coolant temp (actually cylinder head temp sensor in the back of the head) ... I was able to see what temperature the gauge was at at different sections. Has been handy a few times.
There's a few threads around on it here that have been posted previously under AU dash diagnostics ... with results from different people.
Old 29-10-2007, 08:51 PM   #33
FGII-XR6
FGII-XR6's Avatar
i couldn't get it to go back to standard! had to unplug the cluster to do it
Old 29-10-2007, 08:54 PM   #34
HLC
Audi S3
really?
i just held the odo button down for ages. then when i released it, it went back to normal
Old 30-10-2007, 07:28 AM   #35
Mechan1k
Mechan1k's Avatar
I think you will find it is approx 11 seconds ... no less though.
Old 30-10-2007, 11:06 AM   #36
Chamelion
I've tried this and my oil pressure reads as 0, yet I get no warning light in normal mode. Is this something I should be concerned about?
Matt.
Chamelion is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2007, 11:13 AM   #37
Mechan1k
Mechan1k's Avatar
Matt.
It's more of a binary thing.
0 = no warning light (good)
1 = warning light (bad)
Old 30-10-2007, 11:22 AM   #38
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
Matt.
That will be because in your car (low series dash), they have a oil pressure switch. When the pressure reaches a certain level it switches and the oil light on your dash comes on. Mine is the same, always zero.
On the high series dash, they have a oil pressure sender, due to have a oil pressure guage on the cluster.
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2007, 01:55 PM   #39
TwistedEL
TwistedEL's Avatar
...which might as well be a switch because it only ever shows one value
Old 30-10-2007, 04:19 PM   #40
FGII-XR6
FGII-XR6's Avatar
only 1/2 right there! the "gague" on the S2/3 is a fake and uses a switch not a sender it just reads 3/4 or 0 and does not vary. only the S1 got a real gague. that is why as twistedEL says it only shows one value
Old 30-10-2007, 05:00 PM   #41
Mechan1k
Mechan1k's Avatar
Hence why i am putting in an Autometer oil pressure gauge with it's respective sender
