Old 28-10-2007, 06:26 PM   #1
realor
Default car stalls when starting
When I go to start my car first thing in the morning, it usually takes a couple goes. It usually goes like this
engine turns over a couple times, nearly starts
engine starts, runs for 5 secs then stalls
engine starts, runs for 10 secs then stalls
engine starts and runs fine
its usually only the first start of the day when this happens, from then on its fine used: What could the problem be??? its a series 2 manual ute
realor is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2007, 06:45 PM   #2
StealthAu
fuel or spark, whens the last time the plugs and lead were replaced
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2007, 07:03 PM   #3
No Judge
That's Numberwang!!!
No Judge's Avatar
I had what sounds like a similar problem in my AU2 Ghia.
I ended up doing a reset and changed the battery and have not had the problem since...
Hope it helps
www.aufalcon.com.au/only1
FAIRMONT GHIA: SO GOOD, THEY NAMED THEY NEW FALCON AFTER 'EM
Originally Posted by xr6 ausome
Nah the roads to high, your car can never be to low lol
No Judge is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2007, 10:32 PM   #4
waggaclint
waggaclint's Avatar
yeah try resetting the ECU 1st & see if that helps....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2007, 10:42 PM   #5
GK
Walking with God
GK's Avatar
Reset the computer. Then if no joy, change the plugs.
Changing them is a 15-20 minute job and plugs are only $4 a pop for standard items.
If still no joy, then I'd clean the ISC valve, then if still no joy, clean out the throttle body. If that doesn't help any, you could possibly change the fuel filter.
Resetting of AU ECU
http://www.fordforums.com.au/showpos...9&postcount=85
Cleaning ISC Valve
http://www.fordforums.com.au/showpos...9&postcount=43
Cleaning Throttle Body
http://www.fordforums.com.au/showpos...2&postcount=48
Changing Fuel Filter
http://www.fordforums.com.au/showpos...3&postcount=37
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
