Old 24-10-2007, 08:42 AM   #1
whiskers
gone fishing
whiskers's Avatar
Question What to check if anything???????
G'Day all,
I have a 99 series 1 with 250k on the clock the old girl runs like a dream but has developed a couple of oil leaks. I know where they are so this is Just a quick Q&A, I have to replace my rocker cover gasket as that is where one of the leaks is, it is at the back left hand side, is there anything that I should check whilst the cover is off.
thanks in advance
Whiskers
Old 24-10-2007, 08:56 AM   #2
sly
Sly like a G6
sly's Avatar
See if there is any oil sludge buildup around the valvetrain or on the underside of the rocker cover
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2007, 07:54 AM   #3
whiskers
gone fishing
whiskers's Avatar
thanks for the info Sly.
Old 25-10-2007, 03:35 PM   #4
Mechan1k
Mechan1k's Avatar
Check if there is a leak from the cam chain tensioner as well ... at the front of the engine ... behind the power steering reservoir bracket ... on the driver's side of the engine ... this is another common place for leaks to occur.
While you have the intake off ... clean the throttle body butterfly and Idle Control Solenoid out with Carby Cleaner.
I am sure there's probably a few other little things that could be done as well ... I just can't think of them off the top of my head at the moment.
