10-10-2007, 06:49 PM | #1 | ||
Spin 'em Habib !
Wanting to Paint my Wheels , What type of Paint do you use ? is a Two-Pack or a Special Heat Resisting type ?
also , What Prep do you need to Do .. Like , Spotlessly Clean the Wheels ? Scuff them Up Any Ideas would Help .. Cheers Daniel
AU2PWR |
10-10-2007, 06:51 PM | #2 | ||
[ 5L ]
best to get them powdercoated, anything else with come off.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
10-10-2007, 09:38 PM | #3 | |||
All Bran = Regular Member
so I washed them, sanded them lightly, wiped over with Prepsol, let air out of tyres and slotted index cards between tyre and rim, undercoated, sanded lightly, and sprayed two coats of K+H Urethane Wheel Paint and three coats of clear on them. Turned out very well - batteries are flat in camera or I'd take a pic for you. It's as easy as to do. I'm sure that powder coating would be a better, longer lasting job but that would have cost me more than I paid for the rims. |
10-10-2007, 09:41 PM | #4 | |||
... Fear it!
the only way to do it would be to powder coat them!!
Chrysler 300C Sedan
SY Territory Ghia |
22-10-2007, 06:13 PM | #5 | ||
Karasu
2 Pack paints will work fine if you use a good etch primer under them, I use aircraft grade zinc chromate etch primer and have never had any paint chip or flake off, if you decide to take the powder coat route be carefull who does the work, I am constantly having to repaint botched powder coat work.
22-10-2007, 06:33 PM | #6 | ||
the "coating" on the factory wheels is just 2 pack. powdercoating would be too thick and heavy for the wheels IMHO
23-10-2007, 06:38 PM | #7 | ||
2 pac paint, if the existing paint is in good condition you will only need to scuff this with a scourer prior to repainting. problem with power coating is the work needed to retouch any damage. Most aftermarket alloy wheels are painted in 2 pac.
23-10-2007, 08:28 PM | #8 | ||
What would you use to fill in any scrapes/gouges etc...??
A friend of mine works at a powdercoat factory and said he could do mine for around $200. Dunno if thats cheap or not, I guess it must be, mates rates and all. More of a hassle to remove tyres and such, so i might go for the 2 pac option instead. Well whatever i decide to do i'm going for white rims either way.
My Car |
23-10-2007, 08:48 PM | #9 | ||
Spin 'em Habib !
white on White looks nice ..
im going for Black on Burgundy .. Uber cool Cheers Daniel
AU2PWR |
24-10-2007, 04:12 AM | #10 | ||
Young !@#$ Head
I had black on my XR8. i painted them with 2 pac if its not prep properly when the tyre shop change tyres for you they will chip the paint.
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
