Old 27-09-2007, 09:27 AM   #1
FORDavid
FORDavid's Avatar
Default Stereo Light On - Frozen HELP!
Hi all,
my Ford stacker (AU II Fairmont) red 'load' light wont turn off and the stereo wont turn on. The screen doesn't come on so it doesn't prompt me to enter the pin number.
Does anyone know what the heck is going on?
Please Help
FORDavid
FORDavid is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2007, 10:54 AM   #2
aye you
The Origional, The Best
aye you's Avatar
sounds like the unit is blown, which is standard for the stock unit. i'd be looking for a new one
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2007, 11:10 AM   #3
RG
Back to Le Frenchy
RG's Avatar
It's dead. You need a new one.
Old 27-09-2007, 10:56 PM   #4
Damien
Behind The Mixing Desk
Damien's Avatar
Yep, had the same problem. Try disconnecting the power overnight and then reconnect it in the morning. This worked for me and for one of the guys in the T-Series Appreciation forums.
"If there was a drug that could make you smarter, but would cost a fortune, could you afford not to buy it?"
Damien is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2007, 05:59 AM   #5
au2sw
Blown 5L coming
au2sw's Avatar
it seems to be a common problem with the factory in-dash stackers. your best off upgrading your system. there are plenty of options for double DIN or single Din out there. if you go with a single DIN option, you will need to consider getting the change pocket from a low series model though to fill the hole under the head unit. of course, if funds are tight (like mine) perhaps as suggested try disconecting power to the unit over night to reset it. you may just have to do that from time to time though. good luck
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2007, 01:23 PM   #6
FORDavid
FORDavid's Avatar
Thanks for all the advice everyone,
as for the suggestion to try disconecting power to the unit over night - how would i go about doing that? Does that mean disconnecting the battery from the car or just the unit itself, because i wouldn't know how to do the unit.
FORDavid
Old 28-09-2007, 07:24 PM   #7
Bill M
Bill M's Avatar
I had the same issue in my stacker, pulled the fuse and the unit reset itself and happily plays all my favourite tunes. Has performed well for many years since only rejecting a couple of my itunes burned CDs.
cheers
Bill.
AUII XR6 VCT ute
20 years and still going strong!
Bill M is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2007, 07:47 PM   #8
XRLNT-8
Monsoon SIII XR8 220
XRLNT-8's Avatar
Don't forget you will need the pin to unlock it when you power up again. I had same prob couple of months ago, worked for me but had to go to ford with rego papers to get the pin.
cheers,
Simon
XRLNT-8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2007, 08:58 PM   #9
Smoke Pursuit
happend my xr6 VCT when it was brand new all the time, just disconnect the battery and it was all good again, for af ew months..
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Old 29-09-2007, 12:02 AM   #10
FORDavid
FORDavid's Avatar
Yep, i just disconnected the battery for an hour and all was good
Thanks for the advice everyone
Old 29-09-2007, 12:14 PM   #11
Rojo
Rojo's Avatar
cheers
Bill.
I had the exact same thing happen this week !! What do mean by 'pulled the fuse' what did you do, how do you know which fuse it is please ??
Thanks
Rojo is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2007, 09:05 PM   #12
Damien
Damien's Avatar
Glad to hear that suggestion worked for you.
There is a fuse box near your right knee when you're sitting in the driver's seat. In your car's user manual is a diagram that outlines what all of the fuses in that fuse box are allocated to. There is also another fuse box under the bonnet near the battery, the user manual has a diagram for those fuses as well. You'll need some point nose pliers, or a 'fuse puller' (sometimes one of these is in the fuse box itself, a little white claw looking thing) to get the fuses out.
Old 29-09-2007, 09:31 PM   #13
Rojo
Rojo's Avatar
I had a quick look in the fuse box after I read Bills post, think I might leave it to some one who has a better idea of what they're doing than me.
Thanks for the explanation though !!
Old 29-09-2007, 11:54 PM   #14
TwistedEL
TwistedEL's Avatar
Remove the fuse marked Radio 1 and leave the car turned off overnight
Reinstall the fuse in the morning. You will need the security code.
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2007, 06:26 PM   #15
Rojo
Rojo's Avatar
Thanks every one for the advice, I looked up the fuse 'map' in my manual, pulled the fuse out and replaced it immediately, entered the code and it's working fine, didn't even have to re set the radio stations.
So damn happy I didn't have to spend $$$$ buying a new unit.
Thanks again !!
Old 24-10-2007, 12:07 AM   #16
FORDavid
FORDavid's Avatar
amazing how it just all of a sudden works again hey,
Why didn't FORD suggest this to me when i called them??????
