Old 23-10-2007, 10:49 AM   #1
REDAUXR6II
REDAUXR6II's Avatar
Default Engine squeal
Hey All,
I have a problem with the XR6, every time I start the car I get a loud squeal, much like a stuffed fan belt, I have had the fan belt changed to eliminate that but the squeal remains.
Every time I turn on the aircon the noise dies down a little bit.
Would I be safe in assuming that I need my aircon re-gassed?
REDAUXR6II is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 10:52 AM   #2
FGII-XR6
FGII-XR6's Avatar
you need the tensioner reco'd or replaced
Old 23-10-2007, 10:54 AM   #3
REDAUXR6II
REDAUXR6II's Avatar
is that the belt tensioner?
Old 23-10-2007, 10:55 AM   #4
james22
With da Warlords
james22's Avatar
Check your pulleys. Bearing are probably stuffed. Sounds like one of them may be on their way out. Tensioner pulley tends to be a bit of a culprit. Start your car, and (carefully) use a long screwdriver like a stethoscope to find where the noise is coming from.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 10:56 AM   #5
james22
With da Warlords
james22's Avatar
Yes...
Windsor Warlords
AU III XR-8220
Old 23-10-2007, 10:59 AM   #6
REDAUXR6II
REDAUXR6II's Avatar
Cheers, will check this arvo
What should tensioner pulley cost me to replace?
Old 23-10-2007, 11:20 AM   #7
sly
Sly like a G6
sly's Avatar
Hey All,
LOL exactly the same on my Courier once, until one day the Mrs rings me complaining that it made a funny noise and is down on power. Got home from work, lifted the bonnet & found 2 plug leads sheared in half and no A/C belt.
Looked like the bearings or clutch in the A/C compressor were stuffed & the belt chafed on the pulley until it snapped... taking out the plug leads on the way!
If your tensioner & idler pulleys check out OK, that'd be the next place I'd look.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 11:26 AM   #8
REDAUXR6II
REDAUXR6II's Avatar
just to clear something up, are the tensioner pulleys and the idler pulleys one in the same?
Old 23-10-2007, 11:35 AM   #9
GK
Walking with God
GK's Avatar
May I add my caution to be careful to Jame's?
Think carefully before you decide where you're going to place the screwdriver and where moving parts will be in relation to both the screwdriver and your hair, clothing and any jewellery you may be wearing.
It's soooooo easy to get focussed on isolating a noise etc, that you temporarily lose the safety focus.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 23-10-2007, 11:44 AM   #10
REDAUXR6II
REDAUXR6II's Avatar
thanks,
So are the tensioner and idler pulleys the same pulleys? I ask cause I have had the idler pulleys changed.
Old 23-10-2007, 05:06 PM   #11
NC1183
NC1183's Avatar
The tensioner and idler pully are on the tensioner unit, i got both pullies for about $50, or could get the whole unit inc. pullies for a couple of hundred
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 05:40 PM   #12
wazza69
wazza69's Avatar
I have the same problem, i thought, until i got all pulleys replaced and still does it - had a listen and it seems to be coming from inside the timing cover... any ideas what it could be?
Current Rides:
2015 Ford Transit Custom
1967 ZA Fairlane 289W - Thread: https://fordforums.com.au/showthread.php?t=11456233
2005 Suzuki GSX1400
wazza69 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 10:16 PM   #13
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
mate, is your car a V8? if it is i had the EXACT same problem, to make sure its not a pulley, take the serpantine belt off and start the car (only do it for a short while) if the squeek is still there then you got what i had.
I will quote what is written on my bill from ford:
Attend to squeak in front of motor. Diagnostic traced to CMP Sensor shaft squeaking, removed cleaned & lubed. refit, checked OK.
They told me to monitor it, if it returns then they say i need to replace the CMP sensor unit, and they aren't cheap.
hope this helps you out.
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2007, 10:23 PM   #14
FGII-XR6
FGII-XR6's Avatar
it is an XR6
Old 23-10-2007, 11:01 PM   #15
sly
Sly like a G6
sly's Avatar
CMP (Cam position sensor) may be similar in the 6 to the V8. Up to & including the AU, the CMP mounts on a dummy shaft fitted where the camshaft was on the old 250. I wouldn't rule it out.
Sleeper, anyone?
