Old 06-10-2007, 07:38 AM   #1
Rebel
Rebel's Avatar
Default Alloy Rocker Covers
I'm told that not all alloy rocker covers will fit the AUII 220 EFI Windsor. I was hoping to use Ford Performance Racing units. Will they fit?
2008 FG GT 315 EGO #460
1968 Falcon Sports Coupe **2012 PCOTY winner**
https://www.fordforums.com.au/showthread.php?t=11325000
1990 XF Falcon Panelvan
Rebel is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2007, 08:00 AM   #2
howesy
howesy's Avatar
The biggest problem you have is the clearance to the throttle body linkages. Most motorsport covers are 3 inch and over and the low cover on late model injected is 2 inch. You can buy injected 5.0 covers but you pay for them. I have a different inlet manifold than you but the most height I could go to was just over 2 and 3/4 inches before fouling linkages.
So the answer is yes but they must suit injected 5.0 HO type engine
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2007, 01:33 PM   #3
JC
Miami Pilot
JC's Avatar
Yep - and you need to get the truck ones. I'll see if I can get the part number I put on mine. Also you need to bend one of the metal pipes under the manifold for clearance, or use a 1/2" phenolic spacer.
Ford Performance Club ACT
Old 06-10-2007, 01:50 PM   #4
JC
Miami Pilot
JC's Avatar
Here's the info I worked through when I was looking for mine:
Well, I had a small problem with the order from the US, so I go onto Southside Ford (07-33910141) in Bris-Vegas. Cost a little more than I could source them from the US, but now I should have them by the end of the week instead of in 1 to 3 months!
Just so that others know - any of the M-6000 series will fit EB to AU 5.0 motors. the Ford Racing catalogue can be found at:
http://www.fordracingparts.com/home/home.asp. There's a link to the catalogue near the top left of the screen.
I ended up ordering the M-6582-A351R rockers and the 1/2" plenum spacer (M-9486-A52) from Raceparts Australia (07-38076870).
Single Rocker
The pair in the box
Phenolic Spacer
Old 07-10-2007, 12:29 AM   #5
RG
Back to Le Frenchy
RG's Avatar
How much $$$ roughly for the pair JC?
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 09:34 AM   #6
TICK4D-TAS
Club Moderator
Same as what i have just bought for my XR8. I also bought mine through raceparts australia same as you JC. I dealt with Mike there and he was great to deal with. I think from memory mine cost me $370 including freight to Tas. But i also bought the Ford Racing billet oil cap in that price too.
TICK4D-TAS is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 10:24 AM   #7
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
Agreed i bought the Ford Motorsport ones and they were $350..
I too needed to fit a 3/8 phenolic spacer, bought from trickflow, For an edelbrock manifold and they also do the Ford spacers and uses studs and nylocks insead of bolts.. Way more professional imho
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2007, 09:22 PM   #8
Rebel
Rebel's Avatar
Thanks for the info. What is the "phenolic spacer" for. Is it just to give clearance, or does it have a performance benifit?
Old 07-10-2007, 10:27 PM   #9
svo347
AFF's 1st DM.......
svo347's Avatar
its basically a spacer that doesnt soak up or transfer heat. You put it between the upper and lower manifolds and stops the heat transfer to the upper plenum or "heatsoak" You can really feel the difference in temps with one fitted
13.21 @107.7mph
