Old 16-09-2007, 08:17 PM   #1
vini
Default fan belt replacement
hey guys, i have to change my belt on my au1 6cyclinder.
i cant work out how to release the tension pulley. could someone tell me please?
vini is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 08:56 PM   #2
It's not a fan belt you have electric thermo fans but the serpentine belt tensioner has a square holw that takes a 3/8" square sockect drive. You ypur 3/8" drive ratchet wrench or breaker bar in it and rotate clockwise to take the tension off to remove or replace the belt.
Old 16-09-2007, 09:01 PM   #3
Cobra
Bear with a sore head
Cobra's Avatar
You don't even need to do what aussiblue said (Sorry Aussiblue I'm not trying to undermine you) as I normally just grab the belt and lift it up and over the power steering pulley. It can be a little bit of a squeze getting your hands between the the belt and the thermo fans.
Cobra is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 09:10 PM   #4
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Wouldnt that mean it is to loose?
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2007, 09:17 PM   #5
FGII-XR6
FGII-XR6's Avatar
it is self tensioning
Old 16-09-2007, 09:28 PM   #6
InfernoSR
InfernoSR's Avatar
Ok... another stupid question by me... God i gotta learn these cars damn quick... :?
Old 16-09-2007, 09:40 PM   #7
FGII-XR6
FGII-XR6's Avatar
the only stupid question is the one you fail to ask
Old 16-09-2007, 10:05 PM   #8
InfernoSR
InfernoSR's Avatar
Why is that?
Couldnt help that one :P :togo:
Old 28-09-2007, 04:26 PM   #9
XR Lita
XR Lita's Avatar
I know this is s bit of an old thread...but in regards to the serpentine belt, are there any tricks to getting it on and off?
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2007, 05:55 PM   #10
InfernoSR
InfernoSR's Avatar
Use a breaker bar on the lower pulley to help pull it up... this releases tension on the belt and makes it alot easier to replace.
Old 28-09-2007, 05:57 PM   #11
XR Lita
XR Lita's Avatar
How about getting the new belt on? Will it just slip on?
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 28-09-2007, 06:00 PM   #12
InfernoSR
InfernoSR's Avatar
Put it on the same way you took it off... with the adjuster pulley pulled up, there is no tension... you just slip it on... A 3rd hand to hold the breaker bar can come in handy.
Old 28-09-2007, 06:01 PM   #13
XR Lita
XR Lita's Avatar
Awesome. Thank you. That will hopefully be my job for tomorrow...If I have time after work.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 28-09-2007, 06:07 PM   #14
InfernoSR
InfernoSR's Avatar
lol. the pulley has a 1/2" square drive in the centre... use the breaker bar in the square drive and pull it back inwards... this does NOT undo it... release the pulley carefully after the new belt is installed.
Old 28-09-2007, 07:28 PM   #15
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Look up on the underside of the bonnet should be a sticker showing the way it goes on, my tip to get new belt on is turn belt inside out (ribs up) and put around tensioner pulley first, flat side to flat pulley, from bottom of tensioner pulley to top of crankshaft, around crankshaft, now belt is the normal way around, then a/c, idler, power steering, alternator and while holding tesioner tight slip over water pump.
Obviously gotta take out fans first
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2007, 04:13 PM   #16
XR Lita
XR Lita's Avatar
My tensioner pulley has an arm connecting it to the pulley above it. Um......
How do I get around that? I couldn't see any way of getting it on.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 01-10-2007, 07:19 PM   #17
Jastel
Thats normal, it's hard to explain in words but you turn belt inside out and get a small loop of about 4 inches in your hands, approach the tensioner pulley (bottom of the two, the flat one) at 90 degress and hook the loop between the block and the pulley then loop it so that it goes around the pulley, then feed the belt around the rest like I said before
It is confusing at first but easy once you get it
Old 01-10-2007, 07:42 PM   #18
FGII-XR6
FGII-XR6's Avatar
it is 3/8 not 1/2"
