Old 31-08-2007, 12:35 AM   #1
4dlvr
4dlvr
Default somthing from ebay????
http://cgi.ebay.com.au/UNLOCK-FORD-D...QQcmdZViewItem
does this really work????? it says how to unlock you digital speedo and revmeter
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 01:18 AM   #2
4dlvr
4dlvr
from some research on the net all you do is push in the miliage button on the dash and keep it pressed in while you switch the car on, 15 seconds later the lcd will jump into 15 modes of which you can choose from.
let me no if youve tried it, i want to no if its harmful at all lol,
my car is new some one else try it first hehe
Old 31-08-2007, 01:25 AM   #3
4dlvr
4dlvr
man this is mad, it works, turn it into a sticky, heaps fun
Step 1
Insert Key (do not turn it)
Step 2
Press and hold the Trip-Meter Reset Button.
Step 3
While holding the reset button, start your car and continue holding the button.
Step 4
Within 10 seconds, the display should change to "test" (written in a silly LCD font) and the needles will go nuts. Release the Button.
Step 5
Pressing the button will now cycle through some 15 different modes or more.
Breakdown of some of the functions:
1 Press - Shows a Gauge Sweep
2 Presses - Shows all 8's on the LCD (LCD TEST)
3 Presses - Illuminates all the bulbs on the dash
6 Presses - Shows DTC Troubleshooting Codes
7 Presses - DIGITAL SPEEDOMETER - MPH
8 Presses - DIGITAL SPEEDOMETER - KPH
10 Presses - DIGITAL TACHOMETER
Old 31-08-2007, 08:54 AM   #4
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
Yep most of us has done it to our cars, doesnt do any harm, just gives you information about what is going on.
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 09:57 AM   #5
Piotr
Non-Regular Member
The guage sweep doesn't work on my Fiesta. They just drop to the bottom of the range and vibrate for a little while :( work otherwise though
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 10:29 AM   #6
BlackLS
Posts: n/a
Please; don't say you paid for the instructions
Old 31-08-2007, 10:38 AM   #7
zetec
Zoom Zoom
zetec's Avatar
yeah I laugh to think anyone would ever be gullible enough to fall for that! Honestly think that guy, and those who sell the performance chips should be shot. Scum of the earth preying on people, no matter how stupid the suckers are that fall for it.
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 04:40 PM   #8
20focus05
I wanna XR5
20focus05's Avatar
makes you want to send them a message filled up with 'Ha Ha'
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 05:59 PM   #9
Turbodiesel
Torquer
Turbodiesel's Avatar
Sounds cool, I might give it a try. Just one question though, how do you get it back to normal?
Turbodiesel is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 07:25 PM   #10
20focus05
I wanna XR5
20focus05's Avatar
just turn ignition off
Old 31-08-2007, 09:06 PM   #11
Rhubarb
nice find.
I wish it gave instantaneous fuel usage though.
Rhubarb is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2007, 11:31 PM   #12
4dlvr
4dlvr
i found it on the focusfanatics website, also the engine temp mode is telling me that my engine is running at 95deg thats way too low, so im going to change my thermostat see if that solves the problem
Old 31-08-2007, 11:58 PM   #13
Mick K.
Mick K.'s Avatar
Here is similar info to above, but with pictures...
http://www.panuworld.net/misc/focus/index.htm
MK
Mick K. is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2007, 02:09 PM   #14
Turbodiesel
Torquer
Hang on, is this only for the LR Focus or LS/LT as well?
It says on that site "This document does not apply to the new Ford Focus (2005-)."
Old 01-09-2007, 08:47 PM   #15
Al...
Al...'s Avatar
It works on the LS too
Al... is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2007, 08:50 PM   #16
Rhubarb
The trick works on LS focus - I did it this morning.
The difference is that you get a different set of outputs to scroll thru. There seemed to be all those described above plus a heap more although many were pretty useless to a punter like me. eg Apparently my focus' "Personality 1" is set to 57.
Old 01-09-2007, 09:00 PM   #17
jweb
radio off =save petrol :P
Cool
Anyone know if it will work for a fiesta lx?,pretty sure it will,but how.Wanna do it to my sisters car,scare her pretend its broken or something .
Better roads,and better planned infrastructure=higher speed limit :
jweb is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 06:13 PM   #18
Turbodiesel
Torquer
Tried this the other day, works. There's a crapload of stuff to scroll through to get to the goods though, so would be a bit of a hazard to fiddle with while driving...
Old 05-09-2007, 06:55 PM   #19
photn
AFF Post NAZI
photn's Avatar
Yes it will work on fiesta
Old 05-09-2007, 10:33 PM   #20
melbzetec
Old enough to know better
melbzetec's Avatar
Think I should run an item on ebay............"Unlock your LR Focus bonnet BUY NOW $2"....could make a fortune
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 07:34 AM   #21
Scareybear
GRRRR.....
Scareybear's Avatar
Do you take Paypal???
Will it work on other models??
Now - 2007Renault Megane sedan, Steel Gray, 19" Koya Ambush with 235/35R19 Yokohama ADVAN V103, Eibach Pro-Kit.
Gone but not forgotton - Diamond White 2004 LX Fiesta
If you sneeze with your eyes open, do your eyes pop out??
Scareybear is offline   Reply With Quote Multi-Quote with this Post
