Old 15-08-2007, 05:53 PM   #1
ST
ST's Avatar
Default Changing grill?
I'm thinking about changing my grill in the future, never done it before. How easy is it to remove and install a new one? (My car is a series 1 sedan, low bonnet) It looks really easy, but it could be deceiving. :P
2007 BF MKII XR6 CONQUER
ST is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 06:15 PM   #2
Mechan1k
Mechan1k's Avatar
4 clips and a flat blade screwdriver ... pop all of them and it will slide forward and out. Oh there might be a Phillips head screw or 2 at the top (undo them first though)
That's on my AUII ute ... I have done mine several times now.
Old 15-08-2007, 06:25 PM   #3
ST
ST's Avatar
Hmm... Can't see the clips having a quick check. Are series 1s different with this too? They did a hell of a lot with just a couple of series updates!
Old 15-08-2007, 06:28 PM   #4
Mechan1k
Mechan1k's Avatar
There's 2 tabs at the base of the grill next to the headlights ... wide and flat ... can even use your fingers to hold the tabs down as you slide the grille forward.
Undo the top screws at the radiator support and lean the grill forward ... you should be able to see straight down and see the clips.
My AUII ute uses a low series grille (like AUI).
Sorry I have no pics of it ... that I can think of.
Old 15-08-2007, 06:31 PM   #5
Mechan1k
Mechan1k's Avatar
Had a look at the workshop thread ... my grille is the exact same as yours as the XLS used the S-pac grille from the AUI.
Old 15-08-2007, 06:35 PM   #6
ST
ST's Avatar
Ahh sorry, didn't realise. Thanks for the help! I have to pull the tabs up first yes? As the screws won't come undone otherwise.
Old 15-08-2007, 07:04 PM   #7
ST
ST's Avatar
I must be in absolute stupid mode tonight, could you give me a run through of how exactly you did it? Sorry mate, I feel like an idiot.
Old 15-08-2007, 07:17 PM   #8
Mechan1k
Mechan1k's Avatar
The self tapper plastic screws are crap ... you need to undo them first really ... pulling slightly as you undo them ... they should pop out ... well ... they should.
Then the grille should come out from the top a bit for you to reach inside to undo the clips.
You might be able to reach through the lower holes in the grille to get to the clips as well ... if you have thin fingers too.
Old 15-08-2007, 07:31 PM   #9
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
You push the bottom metal clips DOWN and slide grill out
also make sure you take out both bits of the top screw things not just the centre part that unscrews.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 07:47 PM   #10
ST
ST's Avatar
Bloody hell, got the tabs underneath off. But those screws are an absolute ! They won't unscrew no matter what. Any help?
Old 15-08-2007, 08:00 PM   #11
kenz
BOSS Pilot
kenz's Avatar
get a screwdriver and try pulling them out without screwing. They have a sleeve that expands slightly when the screw goes in. I can usually get a finger underneath and push the screw out then pull the sleeve bit out
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 08:26 PM   #12
ST
ST's Avatar
You must have fingers of steel Ken! I cannot push those screws through AT ALL! This is immensely frustrating. Any other alternative I can use to get these B@$TARDS out?
Old 15-08-2007, 08:38 PM   #13
Jastel
Try a pocketknife, thin screwdriver, anything sharp to lever the screw up a bit and then sometimes they will start "screwing"
If not just lever it out
The small scrivet type ones are even worse, half the car is held together by them
Old 15-08-2007, 09:07 PM   #14
ST
ST's Avatar
After 20 minutes of non-stop levering I have ONE out.
Either I am doing this completely wrong or I got some REALLY dodgy screws.
Old 15-08-2007, 09:27 PM   #15
private9
www.TUFFCARPARTS.com
private9's Avatar
haha, nah mate, they are the most frustrating annoying things known to man!
I find the easiest way is to use a small flat blad screwdriver to lever the screw up slightly while I'm unscrewing it with the other hand.
Or, similar to above, but lever whatever it is you're removing, just underneath the screw.
Or, failing that, do what I do best and just get the biggest flat blade you've got, and lever whatever it is you're removing and bust the things out! Caution, this method often results in broken parts, but it is the most enjoyable!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 09:38 PM   #16
Jokular
Jokular's Avatar
Possibly drill them out?
Jokular is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 09:38 PM   #17
ST
ST's Avatar
2 out... Lucky I never give up.
Old 15-08-2007, 09:41 PM   #18
v8falconsrule
Blue ~oval~ Blooded!!!
v8falconsrule's Avatar
once you have mastered the art of removing these scrivets you'll be fine. i use a pocket knife blade..slip it under the centre head and gently wriggle it up and pull it out. the sleeve will now be able to be removed.. once you have them all out you will see the two clips mechan1c was refering to. it's really quite easy once you figure it out, it'll only take 2 minutes next time.
Give me fuel, give me fire!
50th Anniv G6E Turbo in Sensation
Cobalt blue 94 ED XR8 Sprint- resto/ project
v8falconsrule is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2007, 09:50 PM   #19
S3SR
S3SR's Avatar
jeez dont try removing the mud guards then LOL
trick is once they come out slightly get the flat blade screw driver under it and rip it out...dont bother trying to keep unscrewing, this may help for next time, when you put them back squeeze the expander bit (peice the screw screws into) together makes it tighter for the thread to screw into helps removing them next time
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2007, 07:20 AM   #20
GlennBA
GlennBA's Avatar
i reckon! they were a to remove when i had my AU so i cut the scrivets off lol
GlennBA is offline   Reply With Quote Multi-Quote with this Post
