Old 09-07-2007, 09:43 PM   #1
fairmont1998
fairmont1998's Avatar
Default LS Focus temperature gauge
Does anyone know, is the LS Focus temperature gauge fully functional, or is it an "indicator" like the oil pressure gauge in the AU series II & III?
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2007, 01:31 AM   #2
BlackLS
Posts: n/a
up to operating temp (92 or so deg) its a guage then it becomes an indicator. I find it a bit funny, that the water temp stays the same on a 0 deg night 5th gear 80kmh compared to screaming up a mountain pass up around redline on a 30 deg day.
Old 10-07-2007, 04:39 PM   #3
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
Thermostats work like a charm ;)
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2007, 11:25 PM   #4
fairmont1998
I thought as much. On a 5 degree morning you can watch ours climb from stone cold to "normal" in a matter of minutes and it makes the sweep from cold to where it normally sits in a few seconds, making the movement in about 4 steps.
I can tell you that the car definately isn't at operating temp yet by the luke warm air coming out the floor vents :P
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 11-07-2007, 11:37 PM   #5
eXtremist
eXtremist's Avatar
Warm air comes out of my vents when the temperature has just moved off cold, but when its in the middle it gets really hot.
Old 23-07-2007, 05:35 PM   #6
20focus05
I wanna XR5
20focus05's Avatar
I have been taught that most factory gauges are more or less just indicators becuase of the cost of making precise gauges. I have often seen big differences in the temp on the guage and the actual temp when using workshop equipment.
Where after market products are a more precise at a price!
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 05:49 PM   #7
BlackLS
Posts: n/a
If you get into the diagnostics part of the cluster, one of the slides show engine oil temp or similar. temps around 129 degrees and varies almost instantainious when loading the engine.
Old 23-07-2007, 06:21 PM   #8
20focus05
I wanna XR5
20focus05's Avatar
cool forgot about that.
Old 24-07-2007, 02:59 PM   #9
Stugots
2006 Focus LX Hatch
Stugots's Avatar
By the way, what was the coldest reading on your outside air temp gagues the other week? I saw mine at 6°
Stugots is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2007, 11:00 AM   #10
BlackLS
Posts: n/a
-2deg around Bathurst at 3am and 1deg in Campbelltown at 6:30am. Both in the past month... So much for global warming.
When you hit 4 a yellow icicle light comes on to tell you there could be frost on the road and when you go below 0deg it turns red to warn about black ice.
Old 25-07-2007, 11:46 AM   #11
Stugots
2006 Focus LX Hatch
Stugots's Avatar
Wow, pretty cool! boom boom.
Old 25-07-2007, 12:40 PM   #12
melbzetec
Old enough to know better
melbzetec's Avatar
What symbol comes up to warn you about bad jokes??!LOL
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
