Old 17-02-2007, 06:51 PM   #1
newdriver
Default Does high pressure water washing hurt paint and/or wax?
thanks!
newdriver is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 07:09 PM   #2
Smoke Pursuit
Not unless you get too close, using a high pressure cleaner will actually stop swirling as it removes all the crap off the top of the paint.
Old 17-02-2007, 07:33 PM   #3
Martyvan
Martyvan's Avatar
most shopping centre car washes use high pressure hoses as their first stop, and i havnt seen a class action against any of them by disgruntled car owners....
Martyvan is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 10:36 PM   #4
Smoke Pursuit
So do dealers aswell.
Old 18-02-2007, 05:08 PM   #5
Marshy79
HIgh pressure washers are a good thing for the car.... removes most grit and what not to save you rubbing stuff into the paint with your sponge / wash mitt.
The down side to them is that it is high pressure.... and if you have like a chip or something there is a very very small chance this pressure can lift the paint at that point.
When you use a high pressure washer you basically are meant to have it like 1meter away from the paint just to be safe.
Me... i cain it real close to get rid of bugs on the front.. then use it as per normal.
Marshy79 is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 11:46 PM   #6
zetec
Zoom Zoom
zetec's Avatar
Used it for 4 years, love it. Never had an issue, best way to keep the car clean in the water restrictions environment we live in.
2012 Mazda3 MPS
Old 20-02-2007, 10:11 AM   #7
More revs
And some of them I believe you can add a detergent into the high pressure stream.... which is great for cleaning brake stains off alloy wheels.
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2007, 10:19 AM   #8
NA XR6
Just dont get to close and it works great
NA XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2007, 02:31 PM   #9
newdriver
guys thanks!
