Old 10-01-2007, 04:01 PM   #1
boxo
fit 'n' turn
boxo's Avatar
Angry Squeaky XF front end
Hi All
Im new to this site and forums in general so please excuse any bad etiquette.
So here's my dilema i have just changed the upper control arm pivot bushes
in my old xf ute as it was squeaking more than a whores bed. That fixed the problem for all of 5k's now its back just as bad.
Has anyone had this problem before?
Any advice greatly appreciated.
Box
boxo is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 04:04 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Spray it with brake fluid.
Using a 'Hairdressers' waterspray bottle from any $2 shop
Old 10-01-2007, 04:07 PM   #3
boxo
fit 'n' turn
boxo's Avatar
thanks mate still hoping to fix the problem rather than cover it up.
Thanks for the reply.
Old 10-01-2007, 04:12 PM   #4
coupdy do
G'day and welcome
i had the same problem and it was the metal on metal rubbing that caused it, mine was fixed when i replaced them... did you greese them good? have they been torqued up properly? may be the shockies saddle that is worn did you replace that at the same time? You could also try CRC but this won't last if using brake fluid watch your paint.
I know how anoing this is i put up with it for years
coupdy do is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 04:13 PM   #5
GasoLane
Former BTIKD
GasoLane's Avatar
No problem. It used to work for me.
I goes without saying that you DONT get brake fluid on the paintwork though
Old 10-01-2007, 05:01 PM   #6
smally289
growing up is optional
smally289's Avatar
Sure its not the upper ball joint squeaking? Have had this problem many times at work. Some of the aftermarket joints dont have provision for grease nipples. I usually poke a small hole in the rubber boot and spray CRC into it with a nozzle. Give it a try.
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 05:12 PM   #7
kyro_02
V8 wannaabeee
kyro_02's Avatar
probably ball joint... i know what will fix that, an e - series :P
kyro_02 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 05:12 PM   #8
atec77
Originally Posted by boxo
Hi All
Box
Spray auto fluid on the bushes and ball joints wait a while and hose well , normally stops it ( do it on an area you dont care about) as even a little oil makes a mess
Old 10-01-2007, 05:52 PM   #9
boxo
fit 'n' turn
boxo's Avatar
Thanks for the suggestions fellas i will try them out for sure.
Old 10-01-2007, 06:30 PM   #10
Ando_Leigh
Ando_Leigh's Avatar
I have the same problem too.
Replaced all the bushes about 6months back fixed it for about a month but it back.
i also found that when i didn't drive it for two weeks for about a week it didn't do it.
good luck with it all and let me know the results
BA MK11 XR6- Black
Ando_Leigh is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 09:22 PM   #11
sarrge2001
SZII in Silhouette
sarrge2001's Avatar
It's a standard XF feature....... Apparently if it disappears you can go to Ford Spares and order another box of squeaks..........
Strangers have the best candy.......
sarrge2001 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 10:44 PM   #12
MO
MO's Avatar
Spring saddles!!replace them.
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 05:24 PM   #13
boxo
fit 'n' turn
boxo's Avatar
hey guys i tried the brake fluid and crc still no joy.
Just got some new spring saddles which i'll chuck in tomorrow
will keep posting results untill fixed for those interested.
thanks again for your replies and ideas :voldar02:
Box
Old 13-01-2007, 05:45 PM   #14
boxo
fit 'n' turn
boxo's Avatar
And the winner is SPRING SADDLES!!
Congratulations MO And Coupdy Do!
Thanks to all who have replied to this post, legends all.
Box
