09-01-2007, 04:49 PM | #1 | ||
Alpine premium sound system from NC fairlane ghia
head unit, 6 stacker (with bracket), sub, amp and premium sound badge for the interior i just want to know if the stacker unit will hook up to the head unit i have in my AU I Futura? it's got the stacker controls etc.. just no stacker... will the above stacker unit connect up and work with my AU head unit? Thanks for any help you can provide.. Trent |
09-01-2007, 09:57 PM | #2 | ||
Blown 5L coming
um, if u have the unit from the nc, why not fit that in? u have to remove the original head unit for starters ne way. but i would first be checking for the wiring. if that is there and connected to the unit, find it in the boot and check to see if the plugs will mate up. if not u may be able to solder the wiring together, making sure u connect the wires correctly. i dont see there being ne probs with unit to stacker once u have checked these things though.
09-01-2007, 10:45 PM | #3 | ||
hrmm thanks.. i just want to keep the head unit i currently have... unless someone has a stacker from an AU the wanna offload?
maybe i can ring ford and find out if they are compatible.... |
