Old 12-10-2006, 09:30 PM   #1
Cloud 9
The Maltese Falcon
Cloud 9's Avatar
Default Fords KW stats
ok this might seem like a stupid question, but it's one i don't know the answere to.
Do ford australia measure the power on their vehicals from the flywheel or rear wheels?
Cloud 9 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2006, 09:31 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
flywheel.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 12-10-2006, 09:49 PM   #3
charles_wif_xf
Purveyor of filth
As EF said, the figures quoted when talking about the power figures are flywheel. The power figure is an average of a sample of engines they put on the dyno.
charles_wif_xf is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2006, 10:44 AM   #4
Mechan1k
Mechan1k's Avatar
and then it becomes confusing as Holden use a different typre of measurement when it comes to kW ratings as well ... compared to Ford.
Old 13-10-2006, 10:49 AM   #5
mUTHA
DALLY 41
mUTHA's Avatar
why cant we just all get along on the dyno and make the readings from the wheels... who cares if the numbers dont sound as big still its a more acurate reading
mUTHA is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2006, 11:06 AM   #6
james22
With da Warlords
james22's Avatar
not necessarily, the reason why they give you flywheel power is it is much easier to get an accurate reading from an engine that is run on a bench.
Dyno's can be a long way out between 1 and the other. Whereas the avg of 10 engines on a bench gives a preety good indication of power & torque output
Another thing to think about is, to dyno a car the engine must be in, & you would get 2 different reading between a manual and automatic, even using the same engine.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2006, 07:45 PM   #7
Cloud 9
The Maltese Falcon
Cloud 9's Avatar
ah cheers fellors so any1 know wat the series one forte's were? from the rear wheels? guessing it would be the same as far back as the ef because i dont think it changed?
Old 13-10-2006, 08:08 PM   #8
HLC
Audi S3
it you are talking about AU series one forte's, then 157kw at the flywheel
Old 17-10-2006, 08:46 AM   #9
Mechan1k
Mechan1k's Avatar
which works out to about what HLC has in his signature ... it can vary between 110-120 rwkw though ... depends on the tune of the vehicle and how well it has been looked after. Also the auto can give a slightly lower reading than the manual due to stall converter robbing a few kw.
