06-07-2015, 01:53 PM | #181 | ||
GTF does 297km/hr I thought FPV's were limited to 250km/hr?
FG XR6T Ute
300rwkw |
06-07-2015, 02:19 PM | #182 | ||
John bowe & unique car magazine took limiter off did a run. Google it.
G6ET In Velvet & cashmere daily every option available dealer fit sunroof 1 of 2 built in this combination only 1 with sunroof =288rwkw 660nm. FPV BF F6 TYPHOON in TOXIC green BUILT ENGINE & MT built ZF, FORCED PERFORMANCE turbo HTA 37r Turbo e85 26psi= 525 rwkw 1162nm its DMENTD . BUILT & TUNED by ( PROFILE AUTOSPORTS ) first time on dyno after run in = Pacific Ford and FPV Carshow - DMENTD Dyno Run base 22psi on 98 : https://youtu.be/PoONpkk7qJE |
06-07-2015, 03:24 PM | #183 | ||
I thought every HSV since vr was limited from 230-250.
Although mark Skaife drove a HSV R8 to 270ish for the world record, I'd be pretty surprised if the road versions are allowed to hit nearly 280. Might have to look it up. 'Probably' another title you Holden fanboys don't own.....but are happy to claim....because your told u have: But yes John Bowe drove a stock GT to 297.(limiter removed) Edit...For the official world record runs... Apparently you can't make any POWER or AERO upgrades to the car. Oils,limiters and so on are not restricted. Couldn't find anything about probably the most important point. Tyres! Last edited by 1TUFFUTE; 06-07-2015 at 03:34 PM. |
06-07-2015, 03:43 PM | #184 | ||
Ah okay you're talking about a modified GTF gotcha
FG XR6T Ute
300rwkw |
06-07-2015, 03:52 PM | #185 | ||
VF HSV GTS. Speed limited to 250kph
Ford GT 335 speed limited to 255kph And your basing your belief in Holden claiming to have the 'fastest' car In Australia on a test done on a car with its limiter taken off And just so I don't get flamed by the hundreds of hurt Holden fanboys on here...from what I've read...Both cars engineers say their cars unlimited will go about 300kph. John bowe showed this to be true for ford....and we know the GTS has close to the same power as the GT so it should be a fair statement from both engineers. |
06-07-2015, 04:52 PM | #186 | ||
BA/F6 BF/F6 SSV/R TTG
Tailshafts are an issue. The 297 kph run had a modified tailshaft. So the car wasn't stock
With the right power even an old BA can go over 300kph
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
06-07-2015, 05:27 PM | #187 | |||
The world record run attempts CANT change power or aero. Otherwise stock.(wouldn't be surprised if a driveshaft change came under safety anyway.) not sure. |
06-07-2015, 05:45 PM | #188 | ||
Definetly a safety issue. Ford and FPV know the limitations of the stock tailshafts
High power or high speed or both is done safely with an upgraded tailshaft. They make a big mess when they self destruct at high speed. I have seen a few. Balance becomes real important.
06-07-2015, 05:45 PM | #189 | ||||
Maybe a check of Dry Lake Racers Australia will give you a good idea of how difficult it is to go fast. Quote:
Smile - I dare you |
06-07-2015, 07:24 PM | #190 | |||
I haven't seen the dry lake racing site before...but I've seen a million Commodores,stock and tuned in Dubai going close to 300. From memory the highest was a Ve R8 with a Supercharger and mods.....hit 306 and has been mentioned around here before. Have you seen the video yet where John bowe goes to 297? Pretty impressive. I'd say if it wasn't the gearing or similar holding it back....a GT351 would top 300 rather easily. |
06-07-2015, 07:28 PM | #191 | ||
AWD Assassin
+ the FPV rim might crack, apparently they all do that...
Old RIDE 2006 BFGT Gone but not forgotten New RIDE 2018 AMG Mercedes A45 Angry AWD assassin
07-07-2015, 01:00 AM | #192 | ||||
I've also read they don’t have the aero and are very suss with their stability at those speeds. Bowe also mentioned something similar in the Unique Cars article. Quote:
Check out some of the speed records on the Dry Lakes Racers Australia website and you may be surprised at the limitations of many stock cars.
07-07-2015, 01:14 AM | #193 | |||
Well a Ve is the older far less powerful and less aerodynamic car. Compared to the GTS it's a dinosaur. And a modded one with no aero changes will hit 300. There's a lot of stock imported SSs in Dubai that go over 285 as well. My point is if a GT335 can pretty much do it...(297 is as close as needs proving), then the more powerful 351 would finish that off easy! So I'd imagine a GTS should do it too! And I'm not into salt flat running one bit.....perhaps you could just tell us the record for the fastest stock cars on the salt flats! |
07-07-2015, 02:06 AM | #194 | |||
Bathed In A Yellow Glow
The closest to what they call an off the showroom floor stock category, that is without suspension or body (aero) changes is still allowed to run nitrous and they still don’t hit 300km/h. You don’t see stock Aussie cars running those sort of top speeds. Gary Myers Mustang is a long way from stock but it looked cool there. It pulled 273km/h. This pulled 402km/h . Last edited by Express; 07-07-2015 at 02:19 AM. |
07-07-2015, 10:07 AM | #195 | ||
Looks pretty stock. Were do the fares sit
07-07-2015, 10:10 AM | #196 | ||
Cracked rims, sounds bad. How many cases
07-07-2015, 10:46 AM | #197 | ||
AWD Assassin
Was being slightly facecious as I cracked mine recently and was denied a replacement from Ford ( outside of warranty - fair enough ) - but was arguing the "fit for purpose" case.
Either way - I got the standard " they all do that if you hit a bump" response - so was playing devil's advocate with the ability to reach 300 on an FPV rim. Mind you - when I dropped my rim off to the wheel repair factory - i spied another 4 different type FPV rims there for similar repair work...
07-07-2015, 11:10 AM | #198 | ||
Where to next??
Wasn't there a BA that tried to do 300 several years ago? As it neared top speed it was a handful and was shifting left to right big time.
07-07-2015, 11:17 AM | #199 | |||
Render unto Caesar
Apparently it was horrid to drive above 270 - 280. Swerving all over the tarmac. Shows how aerodynamics play a big part.
"Aliens might be surprised to learn that in a cosmos with limitless starlight, humans kill for energy sources buried in sand." - Neil deGrasse Tyson |
07-07-2015, 12:00 PM | #200 | |||
07-07-2015, 01:48 PM | #201 | |||
In the Guin world record run in the R8 Skaife drove...he hit 269 and then 277 for a record of 272 or thereabouts. Not bad in a far older car. Stock I wonder how much diff Tarmac and salt are to the traction of a car. I'd assume it's apples and oranges with the diff of the two surfaces. Not to mention road cars aren't engineered for 'ice'! |
08-07-2015, 03:31 AM | #202 | ||||||
Some quotes from the article where both John Bowe and Dick Johnson jumped behind the wheel of the GT-F and had a few cracks at the 300.
After another run this time with the rev limiter removed, John Bowe said: Quote:
After John Bowe took the GT-HO Phase 3 run to recreate the photo of Mel Nichols driving down the Hume Highway doing over 140mph: Quote:
I use to go down to Florida for the high speed tarmac runs they’d have there each year and they had a lot of serious iron turn up. Even the Euro’s in total stock form with all their power and superior built in aero compared to the Aussie built cars still in many cases could only hit around the 320km/h or so mark which goes to show the Aussie cars are no slouches. It takes a lot to make a car go fast and to be able to keep it on the road at the same time. If someone like Bowe found the GT-F to be a handful with its moving around at that type of speed, heaven help someone without his skills trying to do the same. And yes the GT-F is the fastest driven Aussie car, though admittedly not completely factory stock.
08-07-2015, 09:48 AM | #203 | ||
You can always head down to the Snowy Mountains 1000 if you want to see some cars push 300
http://snowymountains1000.com.au/ |
08-07-2015, 06:26 PM | #204 | ||
08-07-2015, 07:11 PM | #205 | ||
Since you seem to know everything about the GTS, What's the top speed of a GTS with a upgrade tailshaft and the rev limiter removed?
GTF Smoke with Black stripes. |
08-07-2015, 08:09 PM | #206 | ||
Dont know if anyone has even bothered doing that in a GTS yet, maybe head over to the LS1 forum and do a search?
FG XR6T Ute
300rwkw |
08-07-2015, 08:13 PM | #207 | ||
08-07-2015, 08:17 PM | #208 | ||
Where did you source that info?
FG XR6T Ute
300rwkw |
08-07-2015, 08:41 PM | #209 | ||
Got those stats from my ****.
Made it up for a laugh - I appreciate no one other than me found it funny, but after too many drinks waiting for the Ashes it is all about amusing myself right now. |
2 users like this post: |
08-07-2015, 08:50 PM | #210 | ||
It looks like you need to head over to the ls1 forum.
