26-07-2013, 12:30 PM | #121 | ||
Critical Thinker
How often do you pull the basket out of the handle and clean it? It could be that their is a small granule stuck in the basket blocking the extraction process.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
26-07-2013, 12:52 PM | #122 | ||
Call me Spud
Given that the breville is less than 24hrs old I don't think it is that, but I run water through the basket and clean it between each pour. The breville also seems to use water like it is an endless thing, where as the sunbeam gave maybe 6-8 cups from a tank, the breville has given 2, with a little bit of mucking about to prime etc. When I am pouring, I can literally watch the water level drop. Obviously it should drop, but waatchng it drop from one level to the next in just a 30ml pour seems odd.
26-07-2013, 01:19 PM | #123 | ||
I think you need to video the poor and we can diagnose from there
O I timed a poor this morning 18 seconds
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
26-07-2013, 01:20 PM | #124 | ||
Critical Thinker
yeah sounds a bit strange. I'll leave this to hendrix to explain. I'd be guessing to diagnose the issue.
26-07-2013, 04:16 PM | #125 | |||
Rob
given you don't grind your own beans you are a bit limited on what you can adjust. if it is just dripping out, then the only thing you can really do is to dose less (put less in the basket), or tamp with less pressure, or both, until you find a happy medium. its fine for the coffee to drip to start. as long as you get roughly 25-30ml of shot before it goes too blonde it doesn't really matter what the flow looks like. if all variables are correct, it generally takes care of itself (ie, if grind, dose and tamp are all good, the flow will be good). if the pour takes too long to get the desired amount, it can/will start to burn the coffee, which will also affect the taste obviously. sounds like you just need to get used to the idiosyncrasies of the new machine and try different amounts of coffee in the portafilter. only adjust one thing at a time so you know what change made the difference, so either fill your basket the same, and tamp lighter and trial, or fill your basket less and tamp the same, and trial, then fill basket less and tamp light etc. making your own coffee is so much easier in some ways when you grind your own beans. sure, its another variable, but it allows you to dose correctly at all times. if you are having to under dose to get the right pour then you will struggle to get the right amount for your shot, naturally. as for the steam, perhaps the steam performance is just much better than what you are used to. milk texturing technique can take a little while to master. i would recommend watching some youtube video's. they are very helpful. here's one for your machine http://www.youtube.com/watch?v=A65gRj-5bY4 camera work isn't very good though. and another with the top of the range breville but helpful tips just the same http://www.youtube.com/watch?v=A4ByyUmZT28 |
26-07-2013, 07:44 PM | #126 | |||
The machines have a 3 way valve in them that opens to allow water to flow through the group head and when it closes gives a discharge to the drip tray to relieve the pressure created by the pump from the handle so it can be removed. If your unit is chewing through water it has to be going somewhere. If it is not in the cup then it must be in the drip tray. This is symptomatic also of a faulty or stuck 3 way valve. A quick diagnose can be made by removing the drip tray, placing a jug under the group head with no handle installed and turning the water on as if you are making a coffee. If water comes out the head and out to the drip tray at the same time it is faulty. TAKE CARE tho as you will make a mess and the water will be scolding hot. Shut it down as soon as you have seen whats going on. Best way to attempt to rectify this fault is to use an espresso cleaning tablet and run a cleaning cycle as per the manual. this may be successful in unjamming the valve if it is that problem. The second thing to realise is that with the group basket having multiple holes in it the grind you had for the sunbeam will more than likely not suit anymore. Im afraid you wont be able to test the theory much with out an adjustable grinder. A sloppy puck as mention before can be symptomatic of the grind being to course. The fact that the flow is dripping from one side and spurting from the other really doesnt mean to much. It could be uneven packing of the basket, which you could see, or machine on a really uneven surface, which you can see, or the water purely following the path of least resistance. The head will naturally swirl the water in a certain direction and it will just continue in that direction and find the quickest way out. Does the steam wand contraption you are referring consist of the wand and a hollow pipe you put over it? If so then practise a little more cause they work a treat. I have got the milk down to an art with that thing and have on occasion jagged it to the point you think you a re drink cream!! The brevilles do spit water from the steam wand to start with as well. My understanding is they prime the thermoblock with a "bit" of water to start with which runs out and then the pump cycles on/off spitting small amounts of water into the thermoblock which gets converted to steam as it reaches temp. Hope some of this helps!
HendrixHC --------------------------------------------------- 1966 Mk1 Cortina 1982 XE Falcon 1978 XCGS Falcon 1993 XG Ute 2015 FGX XR8 |
26-07-2013, 08:03 PM | #127 | ||
Call me Spud
Cheers. I knew about the steam wand prime, will have to get use to the new wand. I went crom being able to make smooth creamy milk to dishwashing liquid style hahahaha. I will have a look at whether water is coming out of the drip tray or not. I know a new machine generally means new technique, but it was frustrating. Apparantly tonights coffee tasted good, but still not as good as it has been.
26-07-2013, 08:12 PM | #128 | ||
Dont worry to much Spudz. as many coffees as i have made and machines i have set up we always get new ones in and they are all different. Some of the newer ones ( and not so cheap) are just plain **** and dont really work without modifications.
Its like starting from scratch sometimes. All you can do is keep trying and practising! One example was a machine we got straight from the manufacturer on Monday because it had to be in Tuesday to a massive client. ( sales potential was phenominal). They sent a rep over from Sydney to assist with the install. It took us nearly 6 hours to get a coffee hotter than 40 degrees out of it. i ended up telling him to step aside and turfed his tech manual grabbed the milk air injection venturi which needed shortening, scrapped their milk hose and one way valve system and made my own, and got the soldering iron out and melted the milk inlet orifice shut and redrilled a 1.1mm hole to reduce the milk flow. Instant 72 degrees for every cup. He agreed they need to do some redesigning!
26-07-2013, 09:08 PM | #129 | |||
Run a shot without the handle in place and measure how much water you get in 10 seconds. It should be about 60 -100mls. This should give you 50-60mls form a double basket in 25-30 seconds form the time you press the switch, not from the time the coffee first appears. Try and get a non-pressurised or single wall basket that fits, should be inexpensive and there might even be some going cheap on the coffeesnobs for sale section from greg pullman at the moment, you want a double basket not a single. Better to freeze half the shot for iced coffee later than try and use a single basket. Ultimately you need a grinder, even something like a hario hand grinder for <$100 will be better than beans that are pre-ground and stale in a few days and not the right grind for your machine. You could mod the grinder so it works with an electric drill if you are lazy or in a hurry to grind beans. With your undersized tamper, try doing an NSEW type movement so you are tamping the entire puck, otherwise like hendrixhc mentioned the water will just go around the sides of the puck and over extract the coffee. You might even find a glass that is a better fit, so use that for your tamper. There's a lot to read there but it is worth persevering once you've got the hang of it you will be making better than cafe quality coffee for a fraction of the price and it will be effortless. |
26-07-2013, 11:18 PM | #130 | ||
Call me Spud
What I am finding odd is even with an empty basket I am getting splatterijg and the pour seems to come from one side better than the other. The coffee is turning blonde after about 10secs and usually there is not even a shot in the cup. I am trying different things, I even tried using the baskets from the sunbeam. I will get there in the end. I put the frothing wand back on and got dish washing froth straight away. It is getting frustrating as I had my technique pretty good with the sunbeam. Plus my mrs keeps asking me to just go back to the sunbeam so she can have a nice coffee again lol.
27-07-2013, 07:47 AM | #131 | ||
Rob
how much water did you run through when you first got the machine operating after getting it out the box?
from memory i think start up procedure for mine required me to pump through about a litre of water before doing anything else. perhaps yours is similar? how does it pour without the handle in place? could it be a problem with the handle? |
27-07-2013, 05:17 PM | #132 | ||
Call me Spud
Without the handle in place it pours fine. I did notice the handle was easier to secure than the sunbeam, did not take as much force. Also not sure if it is over rotating as then holes end up on an angle when it is locked in, so cups have to be positioned right, not just side by side.
27-07-2013, 05:59 PM | #133 | |||
Rob
you say you used the baskets from the sunbeam. did you try using the group handle from the sunbeam? might be worth a try although i'd be surprised if it fitted. don't be too worried about the over rotation of the handle. as the seal wears that will happen more and more. seals are a cheap item and easy to replace. i'd be having a close look at the inside of the group handle (minus basket). on coffeesnobs i think i read that on some machines, people remove that black plastic stuff. higher end machines don't have it anyway. might be worth doing some research to see if you can do that, otherwise, given its new, i'd take it back. rather than claim under manufacturer warranty, given its only a couple of days old, most stores would just exchange it with another i reckon, rather than stuff around sending it off to breville. |
27-07-2013, 06:00 PM | #134 | ||
Rob
just on breville, their customer service is fantastic!!
27-07-2013, 06:26 PM | #135 | |||
Rob
http://coffeesnobs.com.au/brewing-eq...r-options.html mostly there for those who don't preheat their group handle, but it appears it also assists in directing the shot to the 2 spouts. maybe remove it to make sure its ok, but then leave it fitted as factory. |
27-07-2013, 07:06 PM | #136 | ||
Damn Spudz and his apple cake. I been thinking bout that for 2 days now. Just went out in the kitchen and knocked one up. Should be ready in 35 minutes.
27-07-2013, 10:30 PM | #137 | ||
Call me Spud
Can't knock this one up in 10mins, bloody thing takes 10days lol. She made one with cinnamon and brown sugar and walnuts and one with white choc bits and macadamia. Of course they both still contain apple. Now I am signing off, wr did stocktake tonight and I may have drunk my share of carona. Best to stay off the net tonight lol.
27-07-2013, 10:49 PM | #138 | ||
8 Oz brown sugar, 4 Oz butter,3 eggs, mix, add 1/2 cup milk, 8 Oz self raising flour, 1 can of apples and tablespoon of cinnamon. cook at 160 degrees fan forced for 45 minutes!
Comes out a treat. And no numbers arent typos!
28-07-2013, 08:39 AM | #139 | |||
Lyminge, Shepway, Kent
I am a complete coffee snob, no instant in years. Plunger or stove top (normally Harris gold pack). Here in Geelong I buy coffee at Cravings in Malop St, Coffee Cartel in Breakwater and Adelphi Cafe in Ryrie St. Last edited by nuthin' fancy; 28-07-2013 at 08:51 AM. |
28-07-2013, 11:48 AM | #140 | ||
Anyone here a fan of Greek/Turkish coffee?
28-07-2013, 05:44 PM | #141 | ||
Ive had greek coffee at a greek restraunt, but it wasnt great, and i suspect it had more to do with who made it and less to do with the style of coffee
28-07-2013, 08:25 PM | #142 | ||
28-07-2013, 10:03 PM | #143 | ||
Where to next??
You mean the stuff they use to repair cracks in the road?
28-07-2013, 10:04 PM | #144 | ||
If you are drinking Harris gold pack then you have a way to go before you are a complete coffee snob. harris gold pack coffee is stale before it gets to the supermarket. I roast my own beans and don't consider that I'm a complete coffee snob though others may
29-07-2013, 10:27 AM | #145 | ||
Has Blue Blood
Hi ladies ( just joshin ) , interesting topic ! I didnt think coffee could be so complex. its like being in an art museum , watching the arties waffle on about what D'Vinci was thinking 4000 years ago when he cleaned all his house painting brushes on an old drop cloth .
But seriously , While i Dont drink much coffee at all ,maybe 1 a month , I used to live on a coffee plantation in Papua New Guinea when I was a kid . I love the smell of coffee ,especially fresh roasted beans . I cant handle drinking it . I drink tea like its going out of fashion and cant stand the smell of tea leaves . Go figure ?
Real cars dont wear bowties I'm not arrogent , Just superior
30-07-2013, 08:52 PM | #146 | ||
10-09-2013, 08:34 PM | #147 | ||
Call me Spud
Thought I would get this up again. Still going with the breville, still not making as good a coffee as I did with the sunbeam lol. But still a much nicer coffee than ever before. We go out to cafe's now and some of the coffee served is just plain revolting. My partner had to add 3 sugars to a mocha, just to get the biterness out of it.
11-09-2013, 07:54 AM | #148 | ||
Wow, I would of just given it back.
I had a 3 week holiday in the states a couple of weeks ago, my main concern was finding good coffee. Thankfully there are plenty of nice cafes there now, but you need to spend the time searching for them and ensuring they don't serve drip rubbish. Though we had 1 cafe where my missus sent hers back 3 times before they finally got it right haha.
flickr |
11-09-2013, 08:07 AM | #149 | ||
RIP...
I reckon I'm pushing to have 10 coffees a year. I drink mainly water.
I don't mind coffee, but can barely tell the difference between cheap instant and all the fancy stuff that you buy and my mates try to shove into me with their fancy uber expensive machines. I like this stuff, pure magic...
. Oval Everywhere... Last edited by Sox; 11-09-2013 at 08:19 AM. |
11-09-2013, 10:38 AM | #150 | ||
industrial freaken roast
