Old 01-04-2010, 11:53 AM   #91
blueoval
Critical Thinker
blueoval's Avatar
Originally Posted by Cam
Looks nice shav, but i cant help but thing how much are the temps affected by having the W2A cooler on top of the headers? What if the cooler was in the battery location or somewhere else?
Cam - I got a stainless heat shield over the headers. The cooler is bolted to a thick plate which is bolted to the main frame that is holding the heat shield. Its basically double insulated. Sure the cooler wont escape every degree of temperature that rises, but its doing a pretty good job as it is.
If I was to relocate the cooler to the battery area as you mention, I would need a different cooler type. More pipe work, more cost, not much extra gain.
The breathing is the weakest link at the moment. The car is trying to exhale thru a straw. So I need to get a 3" mandrel system made up.
Sorry to go OT fellas.
If you wanna know more, post in my build thread or PM me.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 11:24 PM   #92
Travisty FTT
'06 Ford Territory Turbo
Travisty FTT's Avatar
Any further updates on the intake there Matt?
Travisty FTT is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2010, 11:38 PM   #93
frd906
my one, eventually, i had to give the fibre glass one back, but i made measurments etc to get it made out of stainless steel also need to get some more pipe, but i will get it done soon enough
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2010, 11:49 PM   #94
Raphael081990
Raphael081990's Avatar
Hey guys im new to this site just reading over people mods etc, i have a 2001 AU II XR6 running the standard airbox cleaner etc that came factory built, with the air intake pipe between the bonnet and the body of the car. Would changing that to a pod increase performance a noticeable amount or is it not worth the hassle.
Raphael081990 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2010, 12:14 AM   #95
Jimmyd
Out of curiosity I did the AU1.5 VCT Ghia to see if it really made a difference. Being a cheap, tight, stingy bugga and not a big fan of Pod filters I figured I could do it really cheap while not having if flopping around under the bonnet - heres how I did it -
Remove airbox lid and solid pipe from flexi pipe.
Remove rubber adaptor from the air box lid, screw down to a piece of timber, run a 3" (75mm) hole saw through it. clean up saw cut and remount onto airbox lid.
Get a 45 degree alloy 3" pipe - cut exactly half way around the bend. Insert into adaptor with a slight upward angle.
Look down the solid pipe form the flexi pipe end - you will see a definate point where the taper from 55mm to 80mm ends - cut off the pipe at this point and throw away the small end (the bit that used to plug into the airbox). smooth out the seam ridges on the outside of the intake pipe (you will see what I mean) to make sure the silicone pipe can seal.
Stretch some 3" (75mm) silicone pipe over the outside of the rigid pipe - its tight but it can be done. Slip other end over the alloy pipe in the airbox, clip airbox lid back on, slip flexi hose back on, bolt down intake pipe to original mount over left hand shockie - pivot alloy pipe around until you get good smooth angles when mounted, tighten clamps.
All done using 1 45 degree pipe, a 75mm clamp and some silicone hose (don't need to use that much, just what I could scrounge and havn't gotten around to trimming down yet...
The partial (ie still using flat panel filter) conversion I have done has not increased the induction noise, lets the VCT spin a little more freely and holds hwy speeds with marginally less throttle angle with no apreciable reduction in lower range torque (by my highly scientific bumometer anyway) - as to fuel economy it will take a few weeks to guage that. Will tidy it up if I decide to leave it on.
James
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2010, 10:23 AM   #96
JC
JC's Avatar
Here's mine:
Modified BA XR8 SS inductions snorkel feeding into G&D box, then stock tubing to TB (with wheel cap instead of curly pipe section off the side).
Ford Performance Club ACT
Old 05-10-2010, 10:58 AM   #97
frd906
looks good
Old 05-10-2010, 11:49 AM   #98
voluntary
Default Intake Pic
My AU111 XR8 motor in a Mustang
Custom stainless intake made by building a box on to fit on top of the lower intake manifold. Took all the sensors off the origional intake and put them in similar places, kept the intake runners the same length as the origional.
My theory was the intake is only an air delivery box, not an air/fuel delivery so providing the airflow and temp sensors can take the right readings then the intake can be any shape you want it to be.
Works real good.
voluntary is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2010, 12:15 PM   #99
voluntary
Still try'n to learn to resize pics.
Old 05-10-2010, 02:03 PM   #100
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
I'm getting mine done this weekend. SS bigmouth, and tubing bent up to replace the original piping from the box to the throttle body. will post pics
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023, 2024
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2010, 03:13 PM   #101
Day-mow
rexnet
Day-mow's Avatar
Works real good.
that looks mental!!!
also re. posting pictures if you open a photo bucket and use the IMG code life will be alot easier ;)
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 05-10-2010, 11:04 PM   #102
voluntary
SEE IF THIS PIC COME OUT BETTER - XR8 220kw crank trigger.
Old 05-10-2010, 11:07 PM   #103
Day-mow
rexnet
Day-mow's Avatar
thats epic!!!!
Old 07-10-2010, 02:34 PM   #104
GasoLane
Former BTIKD
GasoLane's Avatar
Sorry but I had to fly the flag for us LPG folk
Old 07-10-2010, 04:11 PM   #105
LANKY 1
LANKY 1's Avatar
^^ that's certainly interesting...
V8 dreamteam
1st: 2012, 2021
Old 07-10-2010, 05:47 PM   #106
KR1STO
Just another mock-up..
KR1STO's Avatar
LOVE IT!!!!!
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2010, 02:24 PM   #107
WannabeXP
WannabeXP's Avatar
Well i joined the 3 inch club today :P No Pun intended
$9 from my work (supercheap) for a 76mm piece of intercooler pipe. Bargain!!
Some Silicon and a hose clamp later and shes done.
Here are the pictures:
I'm also flying the LPG flag GasOlane
Cheers Jason
WANTED: MOMO Metallic blue steering wheel and Manual gearknob! PM Please!!
Stevo
_____________________________________
05/2000 AUII XR6 5sp|Pacemaker 4480 Competition Headers|Lukey catback|Tickford Azzuro's|Impco LPG Conversion
WannabeXP is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2010, 04:27 PM   #108
SILVA
SILVA's Avatar
I have also put a three inch pipe in today on my AU II. and i fitted a pod filter in the stock Airbox,
i'll send pics soon once i know how.
first i put the 3 inch stainless steel pipe, noticed a small improvment in throttle response.
then i put the pod filter in the Stock Airbox the next day not much differance but little better, i am using a cheap pod for now will get K&N pod filter in the next couple of days
thanks for the ideas everyone
SILVA
SILVA is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2010, 12:49 AM   #109
atomiclord
I drive way too much...
atomiclord's Avatar
Pics or it never happened :p
An easy way is to hit up photobucket.com then grabbing your image link and whacking it between [IMG] these IMG tags [/IMG]
AUIII Straight LPG
Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust
To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat
atomiclord is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2010, 09:39 AM   #110
frd906
pics or ban
Old 13-10-2010, 09:46 AM   #111
WannabeXP
WannabeXP's Avatar
They have the IMG Link ready to go on photobucket,
Copy and paste
Cheers Jason
Stevo
Old 23-10-2010, 07:40 PM   #112
LANKY 1
LANKY 1's Avatar
This is mine. Just got finished today. I got it done at the same place as my exhuast.
Cost me way too much
SS bigmouth, 3" tubing, Lukey Air filter. And it's dual fuel
V8 dreamteam
1st: 2012, 2021
Old 23-10-2010, 07:56 PM   #113
robbyj
Rob
robbyj's Avatar
Nice mate, how much did they charge to do the piping?
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2010, 08:01 PM   #114
LANKY 1
LANKY 1's Avatar
About 230 i think. And pretty sure that would include a few hours of labour and the filter. SS bigmouth was the most costly thing out of all of it
V8 dreamteam
1st: 2012, 2021
Old 23-10-2010, 08:02 PM   #115
robbyj
Rob
robbyj's Avatar
dam... oh well it looks nice ;)
Old 23-10-2010, 08:03 PM   #116
frd906
That sure is a lil pricey, is it mild steel, alloy or stainless pipe
Old 23-10-2010, 08:07 PM   #117
LANKY 1
LANKY 1's Avatar
Just normal exhuast pipe. Yeah certainly was pricey, but being single with little expenses it's ok with me. Only problem is it does touch the fluffy stuff under the bonnet, and will be fun trying to get the filter out with no flexible parts.
V8 dreamteam
1st: 2012, 2021
Old 23-10-2010, 08:08 PM   #118
frd906
would the normal exhuast pipe get hotter then say alloy or stainless
