01-07-2014, 08:12 PM | #61 | ||
Experienced Member
01-07-2014, 08:16 PM | #62 | ||
Yep varnish only left.
01-07-2014, 08:36 PM | #63 | |||
Thailand Specials
Needed new pump, assembly and fuel tank, the tank was rooted.
Had a Mazda 6 diesel with a DPF light on a few weeks ago, forced a regeneration with the scan tool, it sat there for 50 minutes revving up to 3000 RPM until it was completed. DPF light still on. Handball to Mazda, DPF is rooted. There is a reason why there is a whole aftermarket industry around DPF removal lol. |
01-07-2014, 09:02 PM | #64 | ||
bitch lasagne
How much did Mazda want to fix the DPF problem?
01-07-2014, 10:59 PM | #65 | |||
this is an old article , some very interesting bits about petrol/unleaded fumes and the different laws between countries, for example usa requires unleaded fumes be sucked out while filling the tank, other countries are somewhat lax.....Australia / britain etc. also very interesting that the early vintage cars ran on motor spirit which was in fact very very clean , im betting this stuff could be made to run well in modern cars ........ but it costs the oil companies too much coin we will never see it. http://www.whale.to/b/simons.html#THE_BIG_CON_ |
01-07-2014, 11:05 PM | #66 | ||
Thailand Specials
Replacement DPF was close to 5 figures from Mazda.
This is why you only buy modern diesel if you do a lot of highway, no short trips or you'll be back at the dealership when warranty is out with a second mortgage. Or you could just remove it and flash the ECU Here is a pic of a Mazda 6 DPF that someone on another forum fixed up. Best way to fix them lol Last edited by Franco Cozzo; 01-07-2014 at 11:30 PM. |
3 users like this post: |
02-07-2014, 09:36 AM | #67 | |||
Au Falcon = Mr Reliable
Thanks for the link mik, very informative especially if you have kids & live near major traffic. Definately food for thought! cheers, Maka
02-07-2014, 09:38 AM | #69 | |||
Repairer and driver should be fined heavily.
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk |
02-07-2014, 09:52 AM | #70 | |||
Lead was a cheap way to protect cheap engine parts. Lead was also a common factor in spark plug fouling in performance vehicles, requiring regular removal and cleaning. unleaded fuel forced engine manufacturers to come up with better quality materials, which gave us long life engines components. Spark plugs with Platinum could be used, giving us 100,000km worry free driving. A well tuned ULP vehicle emitted much less pollutants than an equivalent Lead fuelled vehicle, due to the chemical catalyst of the exhaust gases. No exhaust gas is safe but I'd rather be next to a well tuned car with a catalytic convertor any day of the week, rather than one without.
02-07-2014, 12:40 PM | #71 | |||
Thailand Specials
DPF and EGR is a ****** bandaid solution to the problem, thats what happens when manufacturers want a quick solution, EGR is rediculous what it does to sensors inside the air intake side and it carbons up everything like a mofo, I'd like to take a look at the inlet side of my Focus if I could be bothered, it would be chock full of crap from EGR, it might work fine for the first 100,000km but afterwards I bet you when sensors are crapped up and the inlet side of the engine is carboning up really badly it will be chucking out more nasties out of the exhaust because of these problems as its not going to be running 100% right. At least the USA is leading the way with SCR systems which is an additive you add when you fill up the car, which is slowly replacing the need for EGR and it allows a DPF to work more efficiently at lower temperatures, instead of burning holes through it like you can see in that Mazda 6 DPF. http://www.agcocorp.com/e3/egr_scr.aspx Last edited by Franco Cozzo; 02-07-2014 at 12:50 PM. |
02-07-2014, 01:11 PM | #72 | ||||
On the other hand; if the vehicle has been tested and found that the engine meets emission specifications without requiring a DPF one, so be it. It's not up to an owner to decide wether a DPF should be removed from their vehicle, because another model does not have one. The DPF is there for a purpose. And the cost of replacement should be factored into the vehicles life time maintenance. It is a serviceable part, just like O2 sensors and Cat Convertors. http://en.wikipedia.org/wiki/Diesel_particulate_filter Quote:
03-07-2014, 11:31 AM | #73 | |||
03-07-2014, 12:47 PM | #74 | ||
Experienced Member
Why not say from all vehicles as they all emit poisonous pollution.
03-07-2014, 01:33 PM | #75 | ||
Lead in fuel wasn't the horrible danger that people were led to believe...when they measured "airborne lead" at roadways, it dropped off sharply as soon as you moved away from the vehicles, because even as a particle lead is "heavy" and "falls" to the road surface. The sides of the road has a higher lead level, but not the actual air itself.
Lead levels in childrens (and the general populace) blood when they banned lead paint and lead solder in tin food cans. It had nothing to do with lead as a petrol additive. Catalytic converters don't actually start working until they're up to temperature, and until then the exhaust pipe is spewing out far worse toxins than the cars in the "bad old days" ever did. I have never seen them here, but in Europe there used to be dire warnings on unleaded fuel pumps about "Don't wash parts in this fuel, don't let it come into contact with your skin, don't breath the fumes (most places around the world have a rubber bellows fitting on the end of the fuel nozzle to catch the fumes but not here in Oz)", and warnings loud and clear that additives in unleaded like Benzine were a dangerous carcinogen. We never got those warnings on our pumps, and we never got the fume-catching rubber fitting on the nozzles of pumps. So stand there and breath in all in while you fill up... The lowering of octane levels was why engine builders of old stuff had such a hard time adjusting...the standard thing to do used to be to shave the head and raise the compression ratio as a cheap and easy way to boost power with other mods, but with a lower octane, you could no longer just whack some off the head and stick it back on...you had to carefully consider the compression ratio and timing to eliminate knock. |
03-07-2014, 07:53 PM | #76 | |||
03-07-2014, 08:48 PM | #77 | ||
03-07-2014, 08:59 PM | #78 | |||
Thailand Specials
Which could just be outside of warranty period if you don't drive your car in a particular way. If my Focus had a DPF I would have ditched it the moment warranty ran out. |
03-07-2014, 09:56 PM | #79 | ||||
03-07-2014, 10:33 PM | #80 | |||
http://www.urbandictionary.com/define.php?term=mkay |
03-07-2014, 11:43 PM | #81 | ||
. Ease up sonny, I've been hands on with since I was 13 and backed it up in the books to get the paper work. Tuned them, built them modified them on lead, no lead, methanol, low comp, high comp & chargers. I don't know it all, not even close, but I know a bit.
03-07-2014, 11:49 PM | #82 | |||
04-07-2014, 03:57 PM | #83 | ||
True.All vehicles emit poisonous gases!The old lead petrol used to leave the spark-plug tips cleanly burnt.But when emission control came in with unleaded fuel the spark-plugs are black(fouled)which look like they're not using all the fuel.
04-07-2014, 07:49 PM | #84 | |||
Unleaded engines use soot as a lubricant[valves] and most [not all] use 10%+ more quantity [WAISTED] fuel to reduce toxic emisions--14.7:1 petrol and 15.7:1 for gas to operate a 3 way catalyst convertor is a long was from optimum 12-13 :1 range that modern lean burn engines ran at. If your plugs are black-its a good chance it has been run hot enough or for long enough.-most of my cars get pink/tan spots from modern synthetic oil or fuel additives.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA- Land Rover 88 .MIDCOAST NSW.
04-07-2014, 09:30 PM | #85 | ||
Experienced Member
In all cars I have had the plugs never looked fouled in any way, brown to black carbon colour deposits but not fouled.
05-07-2014, 09:44 AM | #86 | ||
Yeah,Davehoos,before emission control,electronic ignition & unleaded the way to tell if a used vehicle was burning-oil(cyl.stuffed)was to put your finger in the exhaust pipe.Is that what you're saying that this is no longer the test for modern vehicles because they don't seem to wear out,which is interesting on it's own because I thought that was one of the advantages of lead,it protected the combustion area as well as sealing.One question:did exhaust systems last longer before emission control, because now there's no lubricant entering the exhaust to prevent rust?
05-07-2014, 09:52 AM | #87 | ||
Okay,maybe fouled is the wrong word.Just that black hard deposit that Davehoos described which is normal on modern engines.A soot.The spark seems to be contacting lower down on the base of the plug which provides a bigger spark than just between the gap.
05-07-2014, 10:48 AM | #88 | |||
Unleaded fuel allowed for the use of Platinum spark plugs, allowing for 100,000km change intervals (Tetraethyllead kills platinum). The only time I've seen excess ash build up on plugs with 100,000 - 150,000 km use is when oil consumption is a problem. Not sure what you mean by "spark seems to be contacting lower down on the base of the plug which provides a bigger spark than just between the gap".
05-07-2014, 11:49 AM | #89 | ||
My 1982 Celica fouls the plugs after a few thousand kays, really badly. Been trying to sort it out with different makes of plug for a while, different fuel lead replacement additives, etc. "The 21RC engine just doesn't seem to like unleaded" is the consensus in the end...good thing plugs are cheap.
Still, people laughing at older cars that need all sorts of work to run successfully on unleaded won't be laughing so hard when the government eventually gets around to stupidly mandating ethanol in all unleaded, especially if they've got one of the large list of cars that simply can't use the stuff... |
05-07-2014, 12:33 PM | #90 | |||
Experienced Member
