29-05-2014, 06:39 PM | #61 | ||
Yeah i read that running a car in you should not low load for 100 hours I think!!
But Johnydep thanks because I have never owned a New Car so I guess buying second hand you want your motor to last so the 3 mins couldn't hurt it just gets the revs down!!!! And 93 EB I guess everyone has there ways & everyone has there ways they think of a car!! If yours is just a car to drive then you would just start in it and go but if you have put a fair bit of money in to it then your car turns in to an item you are proud of when people comment on it!! & you want to stay away from the mechanics as best you can also!! my brothers a mechanic and I asked him & he wouldn't drive his with out warming it up for 5mins & my whole family does it & they all own a performance car!! So I hope your not fooling yourself !!! but also depends on your ride No Offence!!!!!
03 BA XR8 SEDAN SILH0UETTE IN COLOR! 98 RON, SCT FLASH TUNED, COLD AIR INTAKE WITH K&N HI FLOW POD FILTER , 4:11 DIFF, HERROD THROTTLE BODY. PEDDERS XTREME-XA COILOVERS !! 247 RWKW 03 BA XR8 UTE WHITE IN COLOR! |
29-05-2014, 07:44 PM | #62 | |||
The heater in my FGII Ute is pumping out hot air within 2 to 3 km from cold, I was amazed at how quickly they warm up. It sounds like Ford has done a lot of work redesigning the block passages to get more heat in around the barrels and less in the head. |
2 users like this post: |
29-05-2014, 10:30 PM | #63 | |||
limiter bang.. limiter bang warm yo up Last edited by pottery beige; 29-05-2014 at 10:37 PM. |
29-05-2014, 10:35 PM | #64 | |||
other stuff gets the warm up and limiter bounce up the corner is that cool |
30-05-2014, 08:42 AM | #65 | ||
You can actually cause damage to older cars with automatic chokes that require accelerator pedal action to fully or partially disengage them by over idling; the rich fuel mix washes oil from the bores. 30 seconds max when cold for a properly tuned car.
regards Blue |
30-05-2014, 09:05 AM | #66 | |||
With my first new car, a 2004 Ford Territory, I've followed my fathers advice (a mechanic by trade). The engine has never had a drop of oil between services, and still goes like the day I took it from the dealer. Here are the Oil Analysis I conducted over an extended period - http://www.fordforums.com.au/showthread.php?t=6663 My second new car is a SS-V ute, I intend to keep this as long as my dad kept his ute. I start the engine, put the seat belt on, check surroundings and reverse out the drive. I'll keep you posted in 10 years time
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk |
30-05-2014, 09:45 AM | #67 | ||
Strategic zip ties sort out those naughty auto chokes
30-05-2014, 09:57 AM | #68 | ||
They're not naughty just designed to require pedal action to work correctly. e.g. on the Mikuni Solex below the automatic choke won't drop down each step progressively closing the choke unless the accelerator pedal is pressed down and released. It is held on each step with spring tension that is only released when the accelerator pedal is pressed lifting the screw from the step allowing the coolant encased bimetallic spring to move the stepped cam around.
regards Blue |
30-05-2014, 11:25 AM | #69 | ||||
Ditto with some quadrajets see http://www.justanswer.com/classic-ca...ded-vacum.html
http://www.carburetor-parts.com/Moto...00_ep_422.html Quote:
regards Blue Last edited by aussiblue; 30-05-2014 at 11:34 AM. |
30-05-2014, 11:40 AM | #70 | ||
Most later models of the forgoing carbies had spring or vacuum operated automatic unloader circuits that unloaded the choke from the stepped cam but earlier models required at least a slight minor blip of the pedal to unload the choke. But perhaps I am too old and this isn't relevant to most current forum users.
regards Blue |
30-05-2014, 12:39 PM | #71 | ||
REAL 4X4'S RATTLE
Since my 4Runner runs an ancient 2.4 diesel with 345,000kms on it, I tend to let it warm up for 5-10 minutes before driving, and then baby it until im sure everything is up to temperature. If I can, I'll let my AU/BF run for a couple of minutes before driving, however that's not always convenient, so I just drive gently until once again I'm certain all drivetrain components are up to temperature. With regards to the 4Runner, is what I'm doing okay? It seems a lot happier when warmed up for just a couple of mins.
THE SLUG - 1985 Toyota 4Runner 2.8L Turbo, 2.5" exhaust, 5" lift, 33" Mickey Thompson MTZs, lots of stickers THE DAILY - 2006 BFII XR6T Process West plenum, intercooler, intake kit, and throttle body relocation, 80lb injectors, 4" dump, twin 2.5" X-Force exhaust, high flow cat, ZF tune, 330rwkw @ 15 psi, 20" staggered MC Racing Simmons copies THE TOY - 2000 AU Falcon 4.0L, 2.5" straight pipe, T5, BA brakes, spool, stripped out, slammed |
30-05-2014, 03:01 PM | #72 | ||
Missing a sock...
I start my XH I6 cold and let it get some oil moving around before dropping it into gear, about a minute. I drive her gently until the gauge comes up to temp, about a quarter on the needle. After that it's all good in my mind to stuff the right Grosby into the loud pedal.
Idling and glazed bores: I call BS on that as it's totally unavoidable in traffic - what are you going to do? Shut down the engine while you wait? Buy a Prius or hybrid if idling is that much of a worry. Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
30-05-2014, 04:58 PM | #73 | |||
Rochester Quadrajets and the like were a nightmare to get right once they had a few years on them. I'll have the modern injection systems anyday, of course I now have to take it to our young mechanic who knows what he's doing. |
30-05-2014, 07:04 PM | #74 | ||
So I guess its safe to say it all depends on your vehicle and its condition, and how much you give a rats about it. But if anything, chances of something going pop would be higher if cold, unless the metal components you have dont expand.
30-05-2014, 07:18 PM | #75 | ||
I had a workmate years ago with a HJ Holden and a 308 and toploader. He would start it up wait for the oil pressure to come up and then do a burnout as he left work everyday.
30-05-2014, 09:51 PM | #76 | ||||
31-05-2014, 01:50 AM | #77 | |||
Let me know!!! 2 mins is not long by the time you get set 2-3 minutes passes by I notice a huge difference with BOSS 260 if its warm & cold & its has just hit 140,000 so I will also tell you if I have any problems Start up!! The person, the car, what you have been told or have not its good to hear everyone's story on there methods!!! Thanks mate!!!!!
31-05-2014, 05:38 AM | #78 | |||
read post #42, a warm up achieves nothing other than burning fuel for no reason as I stated previously it's a carry over from the 'old' days and carby cars. Modern injected cars get to operating temp very fast and don't splutter until they get there like some older cars did I can't believe we're even having this discussion |
31-05-2014, 05:58 AM | #79 | |||
the internetz been the internertz since internertz |
31-05-2014, 07:58 AM | #80 | ||
Regular member
I know this may be controversial starting this in this particular thread - but wouldn't warming DOWN your car be just as important as warming up? Most damage particularly to the turbo on some of our cars would be done when the engine's turned off immediately and the oil's left to cook the bearings..
I know in my ex-F6 the bloody thermostat would kick in even on some cooler days after just doing a city run, no hard running at all - which made me idle the car after I stopped for about 30s before turning it off.. Likely this is to protect the turbo, but now I have the GT - is there any additional benefit to idling the car down for 30s after a heated drive?
CURRENT 2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance. OLD 2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw |
31-05-2014, 08:39 AM | #81 | ||
Where to next??
Ok guys...
While the car is sitting there warming up, is the clutch in and first selected or are you just using neutral and the hand brake? If it's a self shifter, have you 'correctly' engaged park the night before? Wouldn't want to put all that undue stress in that little pin thinggo on the gear box that holds the whole car still? Look fwd to the next half dozen pages of debate, now that we have sorted out all the pro's and con's of letting an engine idle... Or have we?? 20 - 30 minutes?? I think there is a market for down filled, tripple stitched car covers with inlaid electric blanket style heating elements.. Anyway... all this talk of glazed bores got me thinking of donuts and fornication just quietly
5 users like this post: |
31-05-2014, 09:34 AM | #82 | |||
My father, a automatic transmission rebuilder that did most of his time at BorgWarner, told me "never trust Park in a Falcon with the C4 trans". I think it was the XA - XC, the linkages would wear and cause the T-Bar to be in P but the trans levers could be half in/half out. He told me a few story's and seen a few come in with busted rear ends, even saw one come off an hoist.
31-05-2014, 09:46 AM | #83 | |||
back on topic now - Some cars have a function that when you start up, the dash board goes through a diagnostic test. After that it's ready to
31-05-2014, 10:29 AM | #84 | ||
Amongst my cars (too many) I have a 1980 LC Lancer that I have had from new than has done well over 300,000 km (never even had its cylinder head off) and 1963 EH panel van that handed down from my grandfather via my late father. I only wait until the less than 20 seconds oil pressure is up before driving them (both have oil pressure gauges). I think their engine life longevity probably has more to do with regular 5,000 km oil changes and coolant changes every two years.
regards Blue |
31-05-2014, 11:45 AM | #85 | ||
Warming up is a waste of time and fuel, and probably worse for the engine as its operating at low oil pressure for extended periods of time, most engine wear would occur during that time.
Start the car and drive it to get oil pressure up, don't drive it hard till warmed up, warming up has nothing to do with water temp, oil temp is more important as oil has a operating temperature where it works well, that's why later FPV's were fitted with oil temp and oil pressure gauges. You can see the low oil pressure on the gauge while idling. I avoid cold idling as much as possible, actually get in the car and get ready before starting engine, then start up once I am ready to go and drive off, hate looking at the gauge not registering any oil pressure on a cold engine idling away. The warming up thing is only for old carb engines with chokes that run badly when cold, even then, minimal sitting around is best. Warming up by idling a car for anymore than 20 - 30 seconds is a waste of fuel and time, causes excessive pollution, annoys the neighbour, contaminates the oil with blow by, and causes excessive wear on your engine, so there really are no positives to doing it.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave Last edited by XB GS 351 Coupe; 31-05-2014 at 12:13 PM. |
31-05-2014, 12:20 PM | #86 | ||
Two turning.. two burning
That's it, just because the temp gauge says it up to temp, doesn't mean the oil is.. owners of fpv and oil temp gauge cars will realise there is a big difference in the time taken to heat oil VS coolant.
As has been said, start... idle, put on seat belt and drive steadily, for at least 5 mins till oil temp has risen, stationary idle is a waste of time. By driving during warm up your warming diff, gearbox, clutch/auto oil converter etc. You don't see V8 supercars just sitting on the grid, idling during the warm up lap do you? its about warming all moving parts of the driveline..
I LIKE BLOWERS, TURBO'S.. AND ENGINES BIG ENOUGH NOT TO NEED EITHER BLOWN, 2013 FPV GS UTE TURBO TERRITORY GHIA 545ci XB GS UTE Daily, 2006 F250 crew cab BA2 Fairmont Ghia |
31-05-2014, 01:42 PM | #87 | |||
Each time I start up whether hot or cold, fuel injected or carby engined, the first thing after sitting in the car is start the engine then by the time the seatbelt is on, the oil is circulating and its ready to drive off. This has been my procedure for over 40 years now for the many types of petrol cars I've owned. The only exception to the rule I can think of was the older Mazda rotaries where you start it up in the morning, then go back inside for another cuppa. |
3 users like this post: |
31-05-2014, 06:08 PM | #88 | ||
Are all the people on here talking about glazed bores from remote country areas? Living in Melbourne there is no way to avoid prolonged periods of idling unless you never drive anywhere ever lol. Your not gonna get glazed bores on a properly bedded in engine just from letting it warm up for a few minutes each morning. Putting an engine under load when stone cold every time you start it is a good way to shorten its life.
1972 XA Coupe 351 C10 The daily 1974 XB 393 C10 The other daily 1979 XD 351 Toploader Just for fun |
6 users like this post: |
31-05-2014, 06:12 PM | #89 | ||
I see no ones mentioned forged pistons. There must be a few here running forgies and I'm sure they understand the importance of a proper warm up. I never drive off until they stop slapping around in the bores
31-05-2014, 11:37 PM | #90 | ||
Maybe irrelevant to a Ford discussion, but my little 1.4L rocket has an oil and water temperature gauge. It takes about a kilometre's driving to hit 90 degrees water temperature. I can drive all the way to work (8km, 15 min), and the oil will be 80-85 degrees. Normal oil temperature in extended running is around the 90 degree mark.
I do tend to give it a 30 second warm-up at idle as it can run a little "lumpy" if I move off prior to that.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
