03-01-2013, 08:31 PM | #31 | ||
I'm not too sure about that new K&N 57S kit. It looks like all you get is a K&N filter with a new airbox lid? Could be a bit of a gimmick.
http://www.knfilters.com/instructions/57S-4000_inst.pdf |
03-01-2013, 08:41 PM | #32 | |||
Thailand Specials
I might as well as buy the shocks, do everything properly. So far its about $820 from EP or the Focus ST225 Bilstein B8s (assuming same as TDCI?) is 411 pounds, but its coming up as shipping 0 pounds? I'm unsure if shipping is free. |
03-01-2013, 08:46 PM | #33 | ||
Good idea on the B8s. The Eibach springs + the Bilstein B8s = Bilstein B12 package, which is an awesome bit of kit.
You better check the online Bilstein catalogue to make sure the ST225 shocks are the same part number for the TDCI. |
03-01-2013, 08:52 PM | #34 | ||
Thailand Specials
Just did, 2.5 ST MK2 has same part numbers for shocks as the 2.0 TDCI, looks like we're in the clear.
03-01-2013, 09:03 PM | #35 | ||
Kinetic FG X XR8
Got 4 LV's (1 MK2) all TDCi's, 3 of them have been perfect.
1 has been a bit of a lemon! Replacement seat base, console loose and wobbly, replacement bem or bcm?, weird gearbox as in it takes a few seconds (like 5-10) to engage drive and when it does it jolts forward. Still, have ordered 2 LW Trend TDCi's to replace. (we replace at 2 years or 40,000k's) Picking up 1 tommorow. Sent from my GT-I9100T using Tapatalk 2
2015 FG X XR8 Manual Kinetic 2016 SZII Territory TDCi TS RWD Aero Blue 1983 FD LTD - 4.1 EFI - White |
03-01-2013, 09:33 PM | #36 | |||
Thailand Specials
03-01-2013, 09:37 PM | #37 | |||
Kinetic FG X XR8
03-01-2013, 11:00 PM | #38 | ||
04-01-2013, 06:45 PM | #39 | ||
Thailand Specials
Also out of curiosity today I checked the vent temperatures for the Aircon.
We managed to pull 15 degrees at the lowest out of the center vents on fan speed 3, hopeless. I also put my hand around the low pressure side of the aircon pipes, in a good aircon system it will get to pretty much freezing temperature, as in like touching ice. It gets cold, but not freezing. So pretty much the aircon system sucks. We had a Falcon in there managing about 6 degrees out of the vents in the workshop, was a good day for testing out aircon systems. |
07-01-2013, 08:59 AM | #40 | ||
Thailand Specials
Also anyone here got a lowered car and tows a trailer? I'm going to be getting another car in 2014 and I'll be passing down the Focus to the old man, he will retire his car, but he uses it to tow a 6x4 to the tip etc.
So eventually the Focus will probably score a tow bar. Will the shorter springs and shocks effect towing badly? If so I might have to swap them out with the factory springs and shocks for him when he takes the steering wheel. |
08-01-2013, 11:41 AM | #41 | ||
MY passenger seat creaks alot now, not sure if it's because of the heat of late that i'm noticing it or what, makes me sad, just need to have a passenger to keep it planted now D:
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler Plans: Whiteline Rear Sway bar |
10-01-2013, 07:24 PM | #42 | ||
Saw a Corolla towing a car trailer with a Au Falcon on the back the other day, so the Focus should tow a 6x4 easy might be the go to put the factory shocks back on though.
10-01-2013, 11:38 PM | #43 | |||
Where to next??
Most cars can tow - it is interesting that vehicle performance and dynamics / safety have greatly increased, yet towing capacities have dropped. Eg, an XF Falcon is very similar to a TDCI Focus in terms of power, weight and torque - yet you can only tow max of around 1000kg with the Focus yet the Falcon was rated at something like 1400-1600kg I think. It was certainly not uncommon to see one pulling a fully loaded car trailer, nor would anyone blink an eye. I have had 6-800kg draging behind the Focus several times and believe me, in the diesel it hardly raises a sweat. Only adds around 2L/100 to the economy as well. Then you have the Amarok - With a diesel donk that is not all that different to the current model 2L Focus diesel output, yet it is in a heavier body that is also rated to tow.. what 3 tons or something close to that?? Yet... get this - the XR5 shouldn't tow (not rated to according to my handbook). Wonder why?? How much lower are they over standard? 10-15mm?? Thats where my Focus sits when I have a boot full of gear and it still tows fine. More often than not towing limits seem to make little sense at all when you compare a few different cars together.
11-01-2013, 07:48 AM | #44 | ||
Could be it has a lot to do with brakes and body strength rather than pure engine grunt
11-01-2013, 07:00 PM | #45 | ||
Thailand Specials
Also the fabric covering the back of the rear seats has now decided to part from the metal behind it.
She ain't holding up too well with the fully loaded toolbox going in/out and sliding about when driving haha. Also it tends to stall very easily in hot weather, and runs rough at idle, like a miss fire, it jolts the car every 10 or so seconds at idle in hot weather, around 1000-1100RPM if you are idle and holding it there it shakes the car. You pretty much have to slip the clutch out at 1500-2000 RPM in first to get it to move without it wanting to stall. It also doesn't respond well to the accelerator in hot weather, sometimes you can push it in about half way and it just barely goes above idle, then when you let the clutch out it goes to stall, any more and it shoots up past 2000 RPM and making a racket. |
11-01-2013, 08:50 PM | #46 | ||
Do you think a throttle body clean is called for?
11-01-2013, 09:14 PM | #47 | ||
Thailand Specials
19-01-2013, 09:33 PM | #48 | ||
Thailand Specials
Come very close to taking out a roo early hours of this morning, driving home with the parents in my car, got all my lights happening, all sweet, I was talking to Mum and a roo jumps out from the side of the road maybe 100m in front of me heading towards our lane.
Old man: WATCH OUT ROO! I clutch in, mash the brake pedal all the way to the floor, but the accelerator goes down with it (oops) and I start bouncing off the limiter, massive amount of soot coming out the tail pipe . There was a car behind me, it was only us two on the road and he insisted of being up my *** for some reason rather than overtaking and as I'm slowing down hard he nearly shoved his new Mercedes up my Focus' ***. I end up getting to about 10km/h and being off the side of the road a bit, roo goes back the direction it came into the bushes again. The guy behind me seemed to drop back about 500 meters after that. I'm not too happy with the braking performance, unsure if its tyres or just the brakes, once you go past 50% brake pedal, it doesn't seem to really stop any faster, my car is always loaded up though so that could be it maybe. |
21-01-2013, 07:28 PM | #49 | ||
Thailand Specials
Ignore the crap in the boot, occy strap is to hold in my tool box when I'm on the move. I'm not sure if I should even bother taking that back for warranty, or should I just fix it myself? |
21-01-2013, 08:15 PM | #50 | ||
This is a common issue with the hatch. They must use the smallest amount of adhesive possible when it leaves the factory.
21-01-2013, 08:19 PM | #51 | ||
Where to next??
Mine has been 'fixed' 3 times now... still looks the same.
Common factory fault I'm afraid to say Damo.
21-01-2013, 08:35 PM | #52 | ||
Thailand Specials
Might fix it some time this week if I can be bothered at work, I have an idea, watch this space
23-01-2013, 08:15 PM | #53 | ||
Thailand Specials
Wrong thread, oops.
27-01-2013, 05:36 PM | #54 | ||
The tyres on my TDCI (2nd set) are Toyo Teo Plus , at 40000kms old they are now pretty worn.
I am trying to decide what tyres to put on it next -the Toyos were quiet until recently but lack grip. What are your views on say GT radial, and Michelin? |
28-01-2013, 09:07 PM | #55 | |||
Where to next??
Just did 100km in the pouring rain on the freeway and they still held the road very well. Would never have believed they were that used. Can't remember the brand off hand, but they have certainly put in a good innings.
28-01-2013, 09:13 PM | #56 | ||
Thailand Specials
Goodyear NCT5?
Those OEM tyres were junk I reckon, I've got Toyo TEO Plus on them now, and they're quiet but the grip is average. I've got Kuhmo KU31 on my WS Fiesta and they're good grip and quiet: http://www.thewheeldeal.com.au/produ...oducts_id=3277 Our forum sponsor The Wheel Deal also sells them. |
29-01-2013, 10:25 AM | #57 | ||
Thailand Specials
Waiting until mid Feb until my shocks come into stock, then I have to wait until they ship.
Grr. |
29-01-2013, 11:04 AM | #58 | ||
Mid Feb!? I suppose its only 2 weeks or so, then add in 1-2 weeks shipping - you'll have them by end of Feb at the latest I'd hope.
