Old 03-09-2007, 05:47 PM   #331
Perana
Perana's Avatar
If only PBR would sell the lower mount separately...
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 06:02 PM   #332
genebaby
Abuser of Charvels
genebaby's Avatar
They might. You can get the slide pin from Ford. Maybe that bit too. I didn't know about it before sourcing my brakes.
Contraband Facebook
Daily: Tornado MY20 GTI
Retired: Venom BA XR8 - build thread
genebaby is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 07:41 PM   #333
Casper
Contributing Member
Casper's Avatar
This is the Ebay "quick and easy" 330mm upgrade for the BA Caliper. Basically the same as a Terri upgrade except it uses an external bracket instead of a change to the caliper. Not 100% convinced its strong enough but apparently its pretty common (so says sbutler and racebrakes).
http://cgi.ebay.com.au/ws/eBayISAPI...._promot_widget
Older, wiser, poorer.
Old 06-09-2007, 12:44 PM   #334
private9
www.TUFFCARPARTS.com
private9's Avatar
Am I reading the above posts correctly, in that Territory/BF calipers are esentially the same as BA/AU2-3 with slight mounting differences?
I was always under the impression that the calipers were much larger? Looking at mine against the standard S3 ones on the car at the moment, they do look a fair bit bigger, but it is a bit difficult to compare through the wheels.
If the pad sizes are essentially the same, is the only reason for the upgrade to gain the correct mounts to fit over the larger discs?
Old 06-09-2007, 03:42 PM   #335
Perana
Perana's Avatar
BF XR6T/XR8/Territory/BA are all basically the same caliper.. just with a different mounts. AU2/3 have different shaped pad's, but I'm not sure how close the rest of the caliper is.
Territory mounts are useless on Falcon's anyway.. If you have 322mm Front discs you need BF XR mounts or if you have BA Discs you need BA mounts.
Old 15-09-2007, 02:31 PM   #336
Casper
Contributing Member
Casper's Avatar
Originally Posted by JC
Matt - AU1XLS had no prblems with his - they bolted straight up with no brackets rubbing on discs or anything. Perhaps this will be the case for yours. If not, then a 3mm spacer mounted between the rear of the hub and the calliper bracket solves the problem. We (me and someone else) think maybe the hub on the IRS is just different enough to cause this gap issue.
Apparently not. I just went to put the rear BA brakes on my AU IRS setup today and guess what? 3mm spacing issue.
In the end I looked at it, messed with it, looked at doing a spacer, checked the AU rear pad size to the BA rear pad size (identical) and decided that a slightly large disk wasn't worth the issue of having a spacer in there. I left the AU rears on. Just not worth the hassles in the end.
Only problem now is I need to actually paint up the rears to match the BA ones for the fronts now... bugger.
Old 15-09-2007, 03:13 PM   #337
JC
JC's Avatar
Lol, I went through the same thing Shane. In the end, I decided the BA callipers were in better condition than the AU ones, so a 3mm spacer it was. Must be the IRS rear end is just slightly different.
How have you found the fronts (besides looking behind the wheels and there they are)?
Ford Performance Club ACT
Old 15-09-2007, 03:20 PM   #338
Casper
Contributing Member
Casper's Avatar
Apart from a fresh coat of paint and a slightly bigger rotor the BA setup was in no better condition than my AU ones (even the pads were the same thickness) so I just didnt want to stuff around with them. I'll give them a clean and a coat of paint one of these days (soonish) just to bling them up a bit and match them to the fronts when they get done.
I havent tried to change them over yet as doing it on the garage floor doesnt seem to be a lot of fun (or particularly safe crawling under a car only held by jack stands).
I have had a look under there today just to see where the brackets for the sway bar go (needs some more holes drilled and threaded by the looks) and I quickly came to the conclusion its not a 1 person job, I dont have the tools and I dont have the knowledge to do the changeover anyhow. I'll leave it to either the pro's or to someone who has done it before and knows what they are doing. I'll happily help but I'm not feeling that confident to do it myself. I dont want the front end collapsing on me due to a mistake on my behalf. Just not something I will risk.
Old 17-09-2007, 03:29 PM   #339
loxxr6
XB in parts...
loxxr6's Avatar
Oh, apparently for us series 1 owners, we can upgrade our master cylinder to a station wagon one for a slightly better increase in pedal feel.
The station wagon master cylinder is a bit bigger than the sedan one. It'll go in a lot easier than a series 2 one which requires some major work.
Old 18-09-2007, 02:46 PM   #340
Perana
Perana's Avatar
Have finally fitted the BF Turbo brakes.. Needed a 2mm spacer for the rear calipers (this is on an AU2 XR6HP), otherwise all went on well.
Very impressed with them so far..
Old 18-09-2007, 03:12 PM   #341
XR Lita
XR Lita's Avatar
I'm running BA dimpled and slotted rotors on my AU2 with the BA calipers and EBC red pads...
Highly recommend upgrading...It's amazing the difference..
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2007, 10:22 AM   #342
waggaclint
waggaclint's Avatar
does anyone no if commodore calipers ie:VZ or VE calipers are the same as BA/BF? there very similar and i think you can buy them cheaper 2nd hand than ford ones?
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2007, 12:12 PM   #343
genebaby
Abuser of Charvels
genebaby's Avatar
I don't know if they are similar, but I know some shops have been using VE calipers in kits they have made up. Best ring PBR and find out what is the same.
Contraband Facebook
Old 30-09-2007, 09:13 PM   #344
RspecAU
BA GT-P Owner
RspecAU's Avatar
: Ok so what parts do i need to upgrade from AU2 to the Terri bakes???
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
Old 30-09-2007, 09:16 PM   #345
poolkeeper
Its Resonating!
poolkeeper's Avatar
Just checking out www.cebcobrakes.com.au
Can you get a AP Racing 4spot brake kit for an au1. Or am I reading it wrong??
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2007, 07:18 AM   #346
Casper
Contributing Member
Casper's Avatar
yes, you can get them. They have a special bracket that comes with it.
You also get 10% off for being an aufalcon.com member.
Old 01-10-2007, 09:01 AM   #347
poolkeeper
Its Resonating!
poolkeeper's Avatar
Sweet as, I didnt want to go to au2 because my 4000 series rotors AU1, are brand new pretty much.
Old 02-10-2007, 10:01 AM   #348
Perana
Perana's Avatar
BF XR6T/XR8 Front capliers (Territory ones do not fit)
Territory or BF XR6T/XR8 (they both fit) Front (and rear if doing rear as well) Discs
Territory or BF XR6T/XR8 (they both fit) Rear calipers if doing rear + 2-3mm spacer
Old 02-10-2007, 10:28 PM   #349
waggaclint
waggaclint's Avatar
does anyone no if there is any size differance in the rears on a BA/BF wgn or ute to i suppose.... compared to a AUIII..ive scored some fronts and now looking at doing the rears as well....
Old 02-10-2007, 10:32 PM   #350
Casper
Contributing Member
Casper's Avatar
AU rears are the same size as the fronts (287mm I think), BA rears are 303mm.
I just had mine done today, BA front and rears.
Pics here: http://www.fordforums.com.au/showthr...00#post1747500
Old 03-10-2007, 08:16 AM   #351
XR Lita
XR Lita's Avatar
Casper you are correct. The rotor diameter of the AU2/3 rear rotor is 287mm, overall height is 51mm and original thickness is 16mm. The BA rear rotor measures in at 303mm diameter, 50mm height, and 16mm thickness
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 03-10-2007, 03:17 PM   #352
Casper
Contributing Member
Casper's Avatar
I'll certainly be looking into this too. Even though the new brakes are clearly far, FAR superior to the old AU1 shockers the pedal feel is pretty wooden and the travel length is a bit of a change for me. Its not bad or dangerous, just not as comforting as a nice firm pedal.
Old 04-10-2007, 01:06 PM   #353
StealthAu
Braided hoses could help firm it up casper. Also has anyone had the AU1 to Ba brakes done in Brisbane? need someone to recomend a place to get it done
Old 04-10-2007, 01:12 PM   #354
Casper
Contributing Member
Casper's Avatar
yep, I'm thinking I'll go braided hoses as soon as I can.
Old 04-10-2007, 01:17 PM   #355
private9
private9's Avatar
Damn mate, I'm not liking your post at all! I actually bought Terri calipers front and rear a few months back, so looks like I'm stuffed. Strangely though, the brake shop I'm using assures me they've done this before and they will fit. I'm sceptical, but I'll book it in and see what happens. Will update you all probably in the next month or so.
Old 04-10-2007, 01:36 PM   #356
XR Lita
XR Lita's Avatar
Braided all the way around is definitely the way to go. I have it on my XR and it is so much better than the stock feel with the rubber hoses.
If there is any members on here in the Cairns region, come see me at Knights Brake Specialists. I'll show you my car, and can try source bits for you if it's not on the shelf.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 10-10-2007, 11:12 AM   #357
RspecAU
BA GT-P Owner
RspecAU's Avatar
Thanks for that Perana. So i don't need the terri hubs? I'll do before the car gets back on the road.
BUILD NUMBER 006
Old 10-10-2007, 11:38 AM   #358
Perana
Perana's Avatar
Yeah we tried Territory front calipers and they definitely didn't fit an AU2.
AU Hubs are fine.. IIRC from the parts book they AU-BF and Territory hubs are the same anyway.
Old 20-10-2007, 03:18 PM   #359
au^dude
au^dude's Avatar
Its been asked but i cant find it What exactly would i need as in parts to upgrade my AU1 Brakes to at least 330mm rotors.
Stub axles
calipers,
discs,
EB Sway bar (and the pins/bushes for it).
Is that what i need? also why the ED sway bar, I already have a white line one on my cant i just use that?
Thanks
au^dude is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2007, 09:49 PM   #360
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Hey Guys, just finished reading this thread start to finish, quite the information overload!
I'm looking to upgrade the brakes on my A1 ute, i've found a wreckers selling the conversion to AU2 specs -- lower control arms, uprights, stub axles and swaybar for $250 i think this is pretty reasonable price.
I was then thinking of putting on this brake kit from ebay HERE
What do you guys think? any suggestions?
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
