28-05-2013, 08:07 PM | #1 | ||
I noticed after fitting my new wheels, the rear right hand wheel seems to be nicely in line with the guard, whereas the rear left hand wheel sits in about another 7 or 8 mm. Both wheels are measured to the same spec offset-wise.
I noticed when putting on the centre caps, one side wouldn't go on, but the other went on fine. It's as if the threaded stub coming out the center of the hub is slightly longer. Anyone else seen this? My FG XR8 ute has the same problem, only it was about 13mm, so much worse. I appreciate any help. I'm thinking on just rectifying it with a 5mm spacer, but that's not the point. Cheers.
2011 SILHOUETTE FPV GS 315 #0275 20x10", 20x8.5" Lenso D1R's Pedders XA Coilovers Brembo 4/1 Pacemaker 1" 7/8 Headers Twin 3" Stainless Manta Catback XFT Built Motor XFT Custom Surge Tank XFT Stage 3 ZF Final Drive Chromoly Tailshaft KPM Twin Air Filter KPM Stage 2 Intercooler KPM Twin Throttle Body 2.6L Kenne Bell on E85 BlueStreak Circle D Converter 900+ rwhp thanks to Xtreme Ford Tuning |
28-05-2013, 08:38 PM | #2 | ||
Car hasn't been lowered more than factory has it. I am not familiar with the underside of a Falcon but if you lower a Commodore you need to fit an adjustable panhard rod to bring the body back to centre with the diff.
28-05-2013, 08:40 PM | #3 | ||
Yeah mate it's on dobinson ultra lows
29-05-2013, 07:47 PM | #4 | ||
Is it the same with the original wheels; to eliminate one variable in the equation?
29-05-2013, 08:51 PM | #5 | ||
It was explained to me at the tyre shop this was a fairly common problem, caused by the FG Diffs not being 100% centered in the vehicle.
29-05-2013, 10:39 PM | #7 | ||
BEN
The diff cradle isn't centered.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels. 331rwkw. 12.7 sec stock as a rock with a passenger. Now with 620rwhp ready to run the 10 built zf, built tailshaft, corn juice all to come. The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw. |
30-05-2013, 07:17 AM | #8 | ||
bitch lasagne
30-05-2013, 08:31 AM | #9 | ||
Is this difficult to fix?
Currently no V8 in the garage! |
