Old 11-03-2013, 08:17 AM   #1
peterljohnson55
peterljohnson55's Avatar
Default Rust in the AU - How bad can it get?
I am wondering what areas do I have to be concerned about as far as rust goes?
And what sort of costs to repair?
Does anyone have any experience on this matter?
Thanks in advance.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2013, 08:25 AM   #2
raa4.0l
Melted Rubber Fabricator
raa4.0l's Avatar
Au's rust in the boot lid and around the boot strut mounts and also the boot floor and can cost a bit to fix.
Can also go in the sills and then you chuck it and get another one lol
Sent from my GT-I9100 using Tapatalk 2
raa4.0l is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2013, 08:42 AM   #3
Dezza
Parts bin special
Dezza's Avatar
Default Re: Rust in the AU - How bad can it get?
Rust in the bootlid is common on AUs with dealer fitted spoilers. It seems on XRs, they actually seal it up properly so it doesn't happen. On the other hand, if you get a Forte / Fairmont etc. with a spoiler, half the time they didn't seal it up properly around the screw holes, allowing water to get into the bootlid, hence the rust (like on my AU ). You can also get rust behind the taillights and under the front door rubber seals (in the a-pillar)
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2013, 09:12 AM   #4
FGII-XR6
FGII-XR6's Avatar
as above but the AU was actually pretty good as far as rust is concerned, another reason they were a great but under appreciated car
[SIGPIC][/SIGPIC]
Rides:
Old 11-03-2013, 10:50 AM   #5
CFOUR
The Destroyer
CFOUR's Avatar
I've seen 2 go to the junkyard from rust. but I've also seen 1 ba and hundreds of x-series and e-series cars.
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2013, 11:00 PM   #6
TheInterceptor
Cruising...
TheInterceptor's Avatar
Mine has/had:
Boot door strut mounts (have been rewelded at some point by a previous owner)
Under the seals that run along the roof
Under the seals that run along the windscreen/"A" piller
Infront of the passenger front door at the bottom of the "A" piller (iPhone sized rust that pushed through into a big hole)
Lots of rust under and to the left of the VIN plates and in the same spot on the driver side under the wiper cowling
Bits along the rear of the car
Bits near the strut tops in the engine bay
The battery tray has rust all over it
The bonnet has lots of rust near the latch and on either side of the bonnet spear on the outside.
There is a rust peice in the drivers wheel well on the top of the well
There are some rust spots on the roof
Surface rust appearing on the chassis drivers side front
Dont ever ever buy a Sydney car ever
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2013, 12:13 AM   #7
jpblue1000
jpblue1000's Avatar
Any car that has lived around the beach will suffer worse than one that hasn't. Around the top of the windscreen is also a common point, I know 3 that have it and seen 2 at the breakers yards with similar.
My ute has minor rust bubbling from the sill joint. Adelaide car so never been wet!!! but its 16 years old so Im not complaining. My 88 XF had it within 6 months from New!
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2013, 10:39 AM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
SAY WHAAAAT?
I'm just not detecting your sarcasm, right?
AU's are HORRENDOUS for rust. Very few other cars of its age would have as many examples with rust as AU's do.
As I've said before, if you think your AU doesn't have rust, you aren't looking hard enough. There are some exceptions to the rule, but by a huge proportion, the rule is correct.
Old 13-03-2013, 10:59 AM   #9
davistev
davistev's Avatar
I suspect a lot more rusty vehicles will show up after all the floods in the Eastern States.
Just Learning about Cars! Own a 1990 Fairmont and a 1991 Ford Corsair
davistev is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2013, 02:09 PM   #10
crdave
Blue Blood
crdave's Avatar
Originally Posted by Mr Hardware View Post
SAY WHAAAAT?
I never actually knew AU'S were bad for rust. We have three of em and not a sign of rust anywhere, but we do live in SA so maybe that makes the difference.
crdave is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2013, 04:37 PM   #11
Cheese3
The BEST Falcon is the AU
Cheese3's Avatar
I own 2 and no rust . . .
Cheese3 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2013, 09:20 PM   #12
tim_pato
tim_pato's Avatar
4 of the 5 ive owned had it somewhere.
au2 dedicated lpg tonner, just want a wee bit more stab.
wanted TS/TL50 front seats any condition pm me
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2013, 08:24 AM   #13
Maka
Au Falcon = Mr Reliable
Maka's Avatar
I've had a good look & i cant find any - probably in a spot were i cant see it! My au has never been near a beach & has always been undercover. About the boot mounts rusting, I've read reports that some au's left the factory unpainted, but i don't know if that's true.
cheers, Maka
Old 06-04-2013, 10:29 PM   #14
1998galaxyforte
1998galaxyforte's Avatar
It can get bad :( my whole rear LH passenger door bonnet and boot need replacing .... being next to the sea and ungaraged for 14 years and a bit doesnt help either... but repairs have began
S1 1998 FORTE GALAXY BLUE Rare TICKFORD DUAL FUEL + Full T5 Conversion!
MODS: XR6T SNORKEL, LUKEY PANEL FILTER, S2/3 XR SPOILER, 17' TERRITORY STEELIES, GENUINE AUTOTEK PROTOTYPE HAWK STYLE GRILL AND SEMI RESPRAY, ROCKFORD 5X7' SPEAKERS FRONT AND BACK AND FUSION IPOD HEADUNIT, RDA SLOTTED & DRILLED ROTORS UP FRONT
104.1RWKW on LPG
102.1RWKW ON petrol
aufalcon.com.au/aufalcon
New Ride: 04 BA XT Mods: XR6T Snorkel, Sound System from AU
1998galaxyforte is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2013, 11:53 PM   #15
flooded one
I've had a rusted boot lid on an AU. all cars rust no matter what model and make it is no car is completely immune too it either.
flooded one is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2013, 03:14 PM   #16
SantoAU
Defender of the faith
SantoAU's Avatar
was inspecting my uncles 'lane yesterday (he passed away during the week). There's a little around the rear sills and across the top of the windscreen. not sure how easy it would be to get out, may be beyond my mediocre skills
Originally Posted by Revolver 45 View Post
Builds are never finished.
They just get reinvented.
SantoAU is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2013, 03:17 PM   #17
SantoAU
SantoAU's Avatar
must add that the 'lane has spent most of its life parked on a saltpan. I'm very surprised it has so little
Old 05-05-2013, 02:24 AM   #18
bigbadwolf1966
bigbadwolf1966's Avatar
Angry Re: Rust in the AU - How bad can it get?
Ford really did do a poor job on some Au1's around the boot hinge pivot area.
the rest of the bodyshell is one of the better vehicles I've ever worked with, but that area around the boot struts and hinge......I cringe at what I've seen on some lately while collecting parts at the wreckers and working on one of my fathers Au sedans.
plenty with a little rocker panel/sill rust, "A" pillars, around tail lights. but over all they are standing up pretty well for their age.
but that boot area stunned me with the first I found,, and I don't stun easy, I grew up with rusty old Valiants.....lol
DAILY DRIVE: EA 30TH ANNIV. tired old girl, needs love.
skinned knuckle maintainer for petrol head family with multiple AU's, NA's, NC's etc etc.
Landy hoarder extreme:
Central Queensland Australia
Multiple disco's
Multiple series landies
and still looking for more...........
and many many many poor parts donors.....
bigbadwolf1966 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2013, 04:13 PM   #19
frd906
http://www.fordforums.com.au/showthread.php?t=11290691 Check this thread out, you guys havent seen any rust like this yet
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
