Old 01-08-2009, 11:22 PM   #1
nudder12
Default AU2 headlight adjustment
Hi all.
I've seen a couple of threads about adjusting the headlight beams, but they all deal with the up or down direction - which I have no problem with using the orange knobs on the light housing.
My problem is that my headlights don't point along the road as I'd like e.g. the right hand side headlight points back toward the left side of the road too far. Not a huge way, don't get me wrong, but enough to be an issue I want to fix.
I can't find anything that gives that left to right adjustment on the lights. Does anyone have any solutions for this please?
nudder12 is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2009, 12:53 AM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
The lateral adjustment for your headlights is down through a hole on top of the radiator support panel and about 5cm in from where the guard meets the support panel. You need to put a phillips head screwdriver into the hole at about 45deg angled towards the guard and there's a white nylon phillips head screw like knob in there that you adjust. It can be hard to spot unless you know it's there so maybe use a torch to help spot it. Once you find it it's easy as to adjust. I hope the directions make sense. If you can't find it let us know and I'll take a pic tomorrow and point it out.
Bushbasher
PS. Welcome
MINE- AUII Forte
Old 03-08-2009, 09:05 PM   #3
nudder12
Thanks heaps Bushbasher.
I just checked it out and it's exactly as you explained.
Yayyy
