Old 27-07-2009, 05:16 PM   #1
robboxr8
robboxr8's Avatar
Default au series 1 cold problem
hi got meself a series 1 xr8
sometimes when cold and i go into drive the motor starts to knock a bit and the idle dies? would that be the idle solenoid??
im starting to get some niggly faults on it heater switch is broken the clip that holds the flap cable on has snapped, the rear passenger door lock has snapped the worm gear too so its always locked, i can live with that though
and the lugs holding the drivers window switch has snapped too so sometimes the window stays down until ya belt it and then its fine
looks like a big trip to the wreckers sometimes soon
but with the faut goin into drive might give the trans oil a change any tips for doing this on the driveway i can jack it up ok to drop the pan and do the filter but is there any tips to refill the box the hole couldnt be in a more awkward place aye.
also it sounds like i have a cold sticky lifter when i start the car it ticks away for about 3 to 4 minuites until they have started to warm a bit then it runs quiet and nice
time for a nice new cam and some lifters too then
at least the rear shocks top mounts are fine
au s1 xr8
robboxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2009, 05:26 PM   #2
frd906
hey mate try my mate out he works at the brownsplains wreckers and gets stuff as well if you want his number pm me cheers, as they have a sereis 1 au xr8 in the shed all tucked away cheers
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2009, 06:08 PM   #3
blownv8au
Pro Street Au Ute
blownv8au's Avatar
to fill trans use a 1 litre tranny bottle or similar and attach a length of hose preferably clear sealed well and squeeze fluid into box try to get bottle as high as possible and refill bottle as necessary.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2009, 07:56 AM   #4
whiskers
gone fishing
whiskers's Avatar
I went and bought a hand pump bottle from bursons to do my tranny it has a flexible hose and a spout on it at the time it cost me about $20 makes it easy to fill, I also use it to top up the diff if needed.
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2009, 01:05 PM   #5
robboxr8
robboxr8's Avatar
sweet that sounds like the go, what do youse do about lifting to get access i like to keep the box level when i fill em
au s1 xr8
Old 28-07-2009, 03:19 PM   #6
whiskers
gone fishing
whiskers's Avatar
I usually just crawl under as far as I can go. as like you I like to keep the box level
Whiskers
Old 28-07-2009, 05:20 PM   #7
robboxr8
robboxr8's Avatar
best loose the beer gut then
au s1 xr8
