Old 09-03-2009, 08:17 PM   #1
XB2DrSteve
Default Spark Plugs XR8
I have done a search for plugs and have noted that no mention is made that according to Max Ellery, plugs 1 - 4 are Motorcraft AWSF-32EG But the plugs 5 - 8 are AWSF 32E. I am curious as to why two different types of plugs are required.
I also note that some members recommend NGk TR155. But they have a lot longer thread compared to the original Motorcraft plugs is this OK? Steve
XB2DrSteve is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2009, 08:41 PM   #2
honer
Back to N/A land
I believe this is due to the way the current/spark flows
Quote from another site:
Yes, with Ford's EDIS, the plugs on each side receive opposite polarity spark. SO the GND electrode will erode on one side, the
center electrode will erode in the other side....This is why
double platinums are a must for long mileage with EDIS. Not
only that, but the plugs fire on every revolution of the crank, not
every other revolution as with a conventional ignition..
EDIT: On that note, I use the NGK BPR5EFS-13 in my XR8 220, I replace plugs once a year so I couldn't justify the price of the Platinum versions
honer is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 09:53 AM   #3
Hords
Treasure your balls?
Hords's Avatar
I've just bought a set of BPR6EFS-13 for the TS. Just over $25 from Bursons. Currently have the TR55IX which have clocked up 80K. I haven't had an issue with the plugs but a lot of other members are going with the standard NGK plug.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 10:01 AM   #4
RG
Back to Le Frenchy
RG's Avatar
Wow, we'll have to start and AU.com BPR6(or 5)EFS-13 club
Ford did originally state two different plugs for either bank but later revised that to be the same plug for both. NGK "recommend" the TR55IX plug yet also admit that it does not have the correct gap and must be gapped down to 1.3-1.4. They also on the other hand say that their Iridium plugs are not to be gapped :
The BPR6EFS-13 is good for a modded car as it is a colder heat range, for a stocker the BPR5EFS-13 is the go. These aren't an iridium plug so you will need to replace them more often, they are 1/5 the price though at about $4 a plug. I generally change mine out at 15-20k whereas with the iridiums I would have gone twice that.
For the record I know it is stated that iridium plugs are good for 100k but I refuse to believe that and refuse to risk it. I honestly can't see how any plug could last that long.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 10:11 AM   #5
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
So what about the NGK Iridium TR155IX? i just ordered mine :(
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 01:43 PM   #6
james22
With da Warlords
james22's Avatar
Well it's true lol. I've still got the original iridiums in my car after 129,000km - Still going strong, and not missing.
But they will be changed soon. When I inspected them, the centre electrode is a bee's wang off not existing lol
Adam, the plug you are reffering to is the same as the one russ mentioned out of the NGK catalogue. It will preferably need re-gapping as it is not correct. NGK has been notified of this, and is aware of the problem in their catalogue, yet still have done nothing about it :
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 01:51 PM   #7
Peuty
Afterburner + skids =
Peuty's Avatar
So how do you figure they are still going strong then?
Oo\===/oO
Old 10-03-2009, 01:53 PM   #8
Mikal52
WINDSOR
Mikal52's Avatar
Hey Russ when you say 'modded car'.... How modded are we talking here? mine isn't heavily modded but it isn't standard, are you talking bolt on's or internals? Then again mine isn't the xr8 motor either only the 175kw baby... I'm doing coil packs, leads and plugs soon and want to make sure I get the right stuff.
Michael
Mikal52 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 01:54 PM   #9
RG
Back to Le Frenchy
RG's Avatar
Michael
I'd go the 5 then, unless you have detonation issues.
Old 10-03-2009, 01:56 PM   #10
Mikal52
WINDSOR
Mikal52's Avatar
Thanks. No issues thus far... if they dont work well at least they're cheap and I can just get the other ones lol
Old 10-03-2009, 02:05 PM   #11
james22
With da Warlords
james22's Avatar
130k..... and not missing..... You telling me they aren't going strong? I'll be buggered :togo:
Yes they are nearly rooted, i admit that. But I think you get my point
Windsor Warlords
AU III XR-8220
Old 10-03-2009, 02:09 PM   #12
RG
Back to Le Frenchy
RG's Avatar
I feel so sorry for your XR8, 130k on the original plugs. Ouch.
They may not be missing but the gaps will be FUBAR, they won't be performing anywhere near as well as they should and THEY ARE STUFFED. I'll bet you have some detonation issues too, even if you can't hear them.
Old 10-03-2009, 02:12 PM   #13
Peuty
Peuty's Avatar
I just fail to see how you can say something is going strong when they are clearly ready for replacement?
EDIT - What Russell said.
Oo\===/oO
Old 10-03-2009, 02:22 PM   #14
james22
With da Warlords
james22's Avatar
^^^^- As for that I do agree, that they are past the point. And need replacing
Gaps are good, have been re-gapped of course.
I did say they are nearly buggered, yes I admit that. But that is not the point I was making.
My point being. Even though they have 130k on them, they still run fine. No missing, no hesitation, no audible pinging. SO IN MY OPINION.... they are doing really well, considering their AGE, and current CONDITION.
Hence why I said they are going STRONG.
I thought you guys would have understood that the first time. Perhaps I wasn't being clear enough. If thats the case, my bad.
I'm just stating my opinion on the condition of the plugs. I mean honestly, that is very impressive for stock plugs correct? How many would still be working well enough to not detect any kind of a problem after 130k?????
Hence being strong, not in good condition.
END RANT LOL
P.S - Need to see doctor regarding RSI after post lol
Windsor Warlords
AU III XR-8220
Old 10-03-2009, 02:30 PM   #15
james22
With da Warlords
james22's Avatar
Original leads too how about that. Flame suit already on lol
Windsor Warlords
AU III XR-8220
Old 10-03-2009, 02:39 PM   #16
honer
Back to N/A land
My 96,000km original plugs had gaps over 2+ mm on some of them
Old 10-03-2009, 02:39 PM   #17
Peuty
Peuty's Avatar
I think I have said this before, but I feel sorry for your car James...
Oo\===/oO
Old 10-03-2009, 02:47 PM   #18
RG
Back to Le Frenchy
RG's Avatar
OUCH!!
James, service your car ffs :
Old 10-03-2009, 02:57 PM   #19
james22
With da Warlords
james22's Avatar
lol. ok ok, i'll buy new plugs on friday ffs. I'll even start a new thread saying i changed them lol. Happy now :-) rofl
I'm glad i havn't met you guys yet, I can imagine the brown stuff flying lol
I'll make sure she's in tip top condition before I meet ya's, and you confiscate my car lol
Windsor Warlords
AU III XR-8220
Old 10-03-2009, 03:05 PM   #20
RG
Back to Le Frenchy
RG's Avatar
James remeber, serviceorban!
Old 10-03-2009, 03:15 PM   #21
FTE217
T3/Sprint8
FTE217's Avatar
Well I won't bother changing my plugs as much as some here, platinum and similar do last longer than std plugs, hence the recommended 100thou k repalcement.
My previous XR8(owned since new) didn't have a plug change till about 95000k,been on dyno(many) mild mods etc not once did my tuner say lets change plugs (he is a sponser here) as we knew the plugs were fine.
I can understand some here buying the std plug considering cost but paying say $20 x 8 = $160 for 90-10000thou k use is that expensive for doing the job once in your garage ? compared to say hords above paying $25 for 8 and maybe do it twice or 3times depending on use......
I know my time is far too valuable but all to its own.
I'll also add my T3 I have changed plugs twice but only because I have the luxury being in the game but there was nothing wrong with the platinum plugs, infact I passed on 1set to a mate with a XR8 just recently and they work a dream.
Some products are far better than they were in the dark ages......
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 10-03-2009, 03:54 PM   #22
InfernoSR
InfernoSR's Avatar
Re-gapping is no issue... but i'll have to get some feeler guages first... unless they come in before the weekend... inwhich i'll do them at my fathers place and gap them there...
She just ticked over 220,000 officially on saturday on my way to James22's place :P
Old 10-03-2009, 07:32 PM   #23
XB2DrSteve
I have added a photo of my old plug to show that the thread does not go all the way up the plug. The NGK TR155 plugs were threaded all the way to the shoulder. Is this OK? It looks to me if they will go into the cylinder head to far??
Old 10-03-2009, 07:44 PM   #24
RG
Back to Le Frenchy
RG's Avatar
They'll go in fine.
Old 10-03-2009, 10:33 PM   #25
Stav
Smile
Stav's Avatar
The slightly longer plug will slightly cause your ignition timing to be advanced slightly and for your car it will help as your exisiting spark plugs indicate a retarded ignition timing...
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
