Old 07-08-2008, 12:06 PM   #1
XR6_4EVA
Hardcore I6 Enthusiast
XR6_4EVA's Avatar
Default Anyone had experiance with this?
www.shiftkits.com.au has adjustable shift kits for $115, just wondering if anyone has had experiance with these kinds of shift kits?
"How does it work ?
The module alters the signal the engine / transmission control unit provides to the transmission to control the line pressure. By slightly increasing the line pressure, the transmission changes harder from one gear to the next. This not only reduces heat generated within the clutches and bands in the transmission, but also will increase transmission lift and reduce wear."
Ive never had any experiance with tranny mods, anyone clued in on it?
2002 AU XR6 VCT III 'ST'
Liquid Silver
Auto
Full Momo and Leather Trim.
Redback exhaust, high flow cat and Pacey Extractors.
SELLING MY GENUINE 18" AZZUROS WITH TYRES.
FRONT TYRES 95%
REAR TYRES 50%
XR6_4EVA is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2008, 12:12 PM   #2
blueoval
Critical Thinker
blueoval's Avatar
I had a 2 stage kit on my EB XR8. Came with instructions. Fitted it on 1/2 hour which is ample time for a noob like me.
Stage 1 was was the best stage. You could drive like normal, it would feel firm between shifts but when booting it off the lights, I would often get 2nd gear chirpies. Solid shifts.
Stage 2 was harder and frankly it wasnt much better than stage 2. It felt more harsher on the driveline than stage 1. Harder shifts.
Many here will say you can make your own for about $10 but if you dont have an electrical mind like me, spending up to get one of these kits is the next best thing. Plus you can switch it back to OEM mode at any time for lazy shifts all day long.
HTH
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 07-08-2008, 12:13 PM   #3
st33l3y
Pursuit #144
st33l3y's Avatar
Had the Stage 1 kit when I had an auto Forte. You solder in 3 wires to the ECU wiring. Its like being kicked in the back when it changes gears. Quite good fun With the adjustable kits, the hardest shift setting is the same hardness as the stage 1 kit.
2003 FPV Pursuit #144
| Silhouette | 5 Speed Manual | Pacemaker Twin 2.5" System | Pacemaker 2.5" 200 cell cats | Pacemaker 1 3/4" headers | Yella Terra airbox | Herrod Oil Breathers | MGW Short Shifter | 19" Bonspeed Clutch billet wheels | Spoiler Deleted |
st33l3y is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2008, 12:27 PM   #4
PoMmYwOG
if you put a stage 1 shift kit in, does it always shift hard even when driving gently or does it only shift hard when you drive hard?
10' FG XT in Edge (Company Car)
6Spd ZF!!
06' Mazda SP23
5spd auto
Luxury pack
PoMmYwOG is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2008, 12:50 PM   #5
blueoval
Critical Thinker
blueoval's Avatar
it will at its full strength under WOT. Otherwise its just mildly firm. Put it this way, I probably would turn it off in peak hour traffic as going from 1st to 2nd would be annoying.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
