Old 29-06-2008, 09:52 AM   #1
AUIIForte
Default Running Rich
Hey guys, I've used the search function and also manually searched heaps of threads in the AU section, but couldn't find what I was looking for, so I've come to this!
Just after getting an AUTO trans swap (the one going in is fully reconditioned and has 12 months warranty) I've noticed that the car has been chomping through the petrol. I've been driving completely sedately and in 'econ' mode just to give the trans time to wear in. I put in about 20L of unleaded and I usually get about 180km's out of it, but this time I got only about 110-120km's.
Is there anything particular I should look for to see what the problem could be, or is this just expected from a trans swap. and it just needs time to re-adjust?
AUIIForte is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2008, 09:57 AM   #2
Stav
Smile
Stav's Avatar
The same happened to me when my auto got redone.It was the battery reset which sabbotages the situation.Try resetting the computer.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 29-06-2008, 10:12 AM   #3
AUIIForte
Resetting it this way?
http://aufalcon.com/cgi-bin/index.cg...f=techdocs/ECU
Old 29-06-2008, 10:17 AM   #4
AUIIForte
Also, not to have to start a whole new thread, would anybody know what would be wrong with my doors as when I use the key to open the door, only the drivers door unlocks and to open the other doors, I have to press the unlock button on the inside.
Also, one of my back doors does not lock. All other doors lock when I lock up the car from the drivers side door, but not the one at the back. It just remains unlocked where ever I go. Anybody know how to fix this?
Old 29-06-2008, 10:34 AM   #5
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
As for your first problem, you need to reset the keypad (reprogram it) again.
For your second problem , it sounds like the door locking actuator mechanism is broken ( the plastic wormgear inside the actuator breaks ). It is possible to fix the actuator with a bit of messing around, or just goto the wreckers and get another one (but they are not cheap for what they are ! ) . cheers.
:eclipsee_
XR6-VCT-2000 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2008, 10:40 AM   #6
Bobman
Regulator
Bobman's Avatar
Edit: XR6-VCT-2000 beat me to it
This is standard on AUII, BA, BF and FG Falcons. It's the two-stage locking system, introduced IIRC after all the car-jacking incidents in Sydney and Melbourne post 1998. You can change it to just unlock all doors, via programming the remote. Check your owners manual.
That would be a faulty actuator. In some instances the lever on the actuator gets caught, which then fixes it, but most of the time the actuator has died (very common and very easy to replace).
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2008, 05:52 PM   #7
NC1183
NC1183's Avatar
So are you unlocking the car with the key or the remote, if its the remote then the guy's above are right, just need to change the locking strategy (spelling) ie. one or all doors. If using the key i'm not sure, i'm pretty sure my ute unlocks both if i use the key and sets off the alarm so everyone knows you've got a flat remote battery
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
