06-01-2008, 01:33 PM | #1 | ||
I am looking for information on how to remove and replace an alternator in an AU 2
Cheers |
06-01-2008, 01:57 PM | #2 | |||
Blown 5L coming
just had to repair my alternator just the other day actually...will have to replace it soon though. you need to take the serpentine belt off, disconect battery, unplug alternator and undo nut and bolt holding wiring loom. undo and remove 2 bolts at the front holding the alternator in place (one holds the support bract for the power steer pump) and the bolt on th back holding to the bracket (may be easier to just remove the bracket from the block as well)
i found it easier to do everything with the thermo fans out of the way too. just 2 10mm bolts at the top of the shroud and unplug the fan loom. alternator just drops down and pulls out from under the car. hope this helps col
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
06-01-2008, 02:14 PM | #3 | ||
Cheers, thanks for the info, i will get to work
