Old 16-05-2010, 08:20 PM   #1
josh_hartman
Default 351 windsor into xr8
i know where i can get a 351 windsor. how well would this fit in the au. would i have to change everything as i would want it injected
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 08:25 PM   #2
frd906
you cant put a older engine into a newer car, unless u adhere by the emission laws etc
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 08:26 PM   #3
Cam
Stroking it...
Cam's Avatar
I could type a huuuuuge post, but i am lazy.
So look at someone who has done it before..
http://fordforums.com.au/showthread.php?t=11271195
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 09:04 PM   #4
BZINGA
Powered by Ford
BZINGA's Avatar
I was going to suggest this thread also but just stroke the 302 to 347 and you dont need to worry about engineers reports etc and all your parts are bolt on off the shelf stuff, less of a headache.
BZINGA is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 09:53 PM   #5
josh_hartman
yeah i agree with the 347 bit. plus you can get a 347 short motor from the states for 2300
Old 16-05-2010, 10:07 PM   #6
cedric
who is that through and is that us dollars,freight,duties ,gst ect. thanks
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2010, 06:08 AM   #7
Cam
Stroking it...
Cam's Avatar
I tend to disagree with the "ditch the 351 and build a stroker"
Why? Because I have a 347 and was looking at a 351, I have since changed my mind, but the idea does have merrits.. An early 351 non roller block will handle a LOT more power then our ****y late model 5L, thats what the appeal was to me, as well as the possibility of stroking the 351...
But short answers:
Is there a lot to change to make it EFI? Yes
Can it be done? Yes.
Can it be made legal? Yes
Is it a MASSIVE amount of work? Yes
Will it work out cheaper to buy an Dart block and stroke it? Maybe..But it WILL be less stuffing around..
Although as toyotaxr8 has done it (in the thread i linked earlier) a lot can be gained from reading his thread and asking the right questions..
Had: 347ci AU
Old 17-05-2010, 06:18 AM   #8
BZINGA
Powered by Ford
BZINGA's Avatar
My old 347 made 470hp and was with a standard block, engine has been together for 7 years now and still goes strong, i don't own the engine anymore but still know the owner of it now. Depends on what your using the car for but i still stick with the stroker idea.
Old 17-05-2010, 07:03 AM   #9
Cam
Stroking it...
Cam's Avatar
Fair call, there are a few late model weezors running around the 300rwkw (540hp) mark. But block strength is a problem. It depends on the power your after.
I am running about 395hp on a very mild 347, I had thought about boosting this engine as its setup perfectly for it, but it would've put me well over that 540hp at 6psi and will eventually see my block let go..
It depends what the OP wants from the engine....Big power and late model 5L's do not mix...Keep rpm down, on a good tune and you "may" have it last...
Had: 347ci AU
Old 17-05-2010, 07:16 AM   #10
BZINGA
Powered by Ford
BZINGA's Avatar
Yeah that's it, all comes down to what you want out of it and weigh up which of the 2 engines suits what your after, both aren't going to be cheap.
Thread Tools
Display Modes
