Old 10-05-2005, 09:23 PM   #1
prabbit
Default really, really, quick !
REALLY QUICK !!
http://www.ccpc.net/~jaho/images/jmp/rex2.jpg
Old 10-05-2005, 09:25 PM   #2
Peuty
Afterburner + skids =
Peuty's Avatar
Like, how quick?
Looks cool!
Oo\===/oO
Old 11-05-2005, 12:00 AM   #3
Kapn_Kiwi
It is hard...
Kapn_Kiwi's Avatar
Originally Posted by Peuty
Like, how quick?
Looks cool!
I DON'T THINK YOU FATHOM HOW QUICK
Seriously though, that looks pretty awesome, any details?
I could eat a knob at night...
Kapn_Kiwi is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2005, 12:27 AM   #4
prabbit
Default hows this....
Whats more you can order a kit, all you need is a donor engine :>
Regards Prof. Rabbit
Chassis: Multi-tubular steel chassis frame.
Engine: 1164cc Inline 4 cyl., DOHC, with Ram-Air.
Transmission: Sequential 6-Speed close ratio gear box, purpose designed reverse gear, rear wheel torque damper.
Front suspension: Unequal opposed triangular arms, adjustable dampers with coil overs, sway bar.
Rear suspension: Swinging arm, dual adjustable dampers with coil overs.
Steering: Rack and pinion (2.25 turns lock-to-lock), leather steering wheel.
Brakes: Front discs: Cross-drilled discs, 11in.(280mm) diameter, 4-piston aluminum calipers.
Rear discs: Cross-drilled disc, 10in.(254mm) diameter, 2-piston aluminum caliper.
Wheels and Tires : Aluminum 7"x16" front, 11"x17" rear, 195/50/ZR16 front tires, 315/35/ZR17 rear tire.
Body: Reinforced fiberglass plastic-sandwich construction, carbon fiber windscreens and headrests.
Cockpit: Side-by-side 2-person seating, adjustable backs, adjustable foot-pedal box, 3-point retractable safety belts.
Dimensions: Wheelbase: 90in(2286mm);
Width: 78in.(1981mm);
Length: 138in.(3500mm);
Height: 42in.(1067mm);
Dry Weight: 900lbs (410kg).
Fuel Capacity: 7.5 US gal. (28L).
Performance: 0-60 mph: 4.1 sec.
Top speed: 140 mph.
Lateral acceleration:1.9g.
Old 11-05-2005, 12:32 AM   #5
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Slower than the bike the engine came from...... Jeeez. Wanna make a bike slower? add a wheel and double the weight.....
Oh, and I seriously question the 1.9g lateral, you ain't getting nearly 2 g without 4 wheels, slicks and some downforce. It might be an instantaneous peak lateral, but it shure wouldn't hold it on a handling circle.
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
