Old 13-01-2007, 04:38 PM   #1
FS5
Default cooling down between runs???
is there any advantage to letting your car cool down between runs ?dose it increase your mph or drop your ET ?
thanks guys jake
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 05:25 PM   #2
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
If the motor is allowed to get hot and stay hot, you get a heat soak in the motor, on a EFI motor there are sensors to pick up this sort of thing and when they do they will pull out some ignition timing and/or possibly add more fuel to stop pinging, doing this will reduce power but keep the motor safe.
The problem is worse on a forced induction engine as intake air temperatures rise under boost and if you start with warm air or warm components you will be loosing more power
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 11:59 AM   #3
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
With ther Turbo's most guys will pop the bonnet and cool down for 60 mins or so before running again.... Too much heatsoak...
Stomp 'n' Steer
FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com
Bluehoon is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2007, 12:46 PM   #4
ebxr8240
Performance moderator
ebxr8240's Avatar
Take a few bags of ice and leave on inlet between runs...
This is where w2a intercooler help in theory, but a weight gain....
In this heat at present all cars are effected....
Daily driver GTE FG..
Old 21-01-2007, 06:55 PM   #5
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Mine did the best mph it ever did hot lapping (6 or so runs back to back)on a high 30c day, maybe the extra heat in the manifold helped with efficiency and so made more hp.
This is a carbed engine,and the motor was not one to get hot,even hot lapping only got water temps to 195f,I think EFI engines appreciate the cool down though..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2007, 10:13 PM   #6
ebxr8240
ebxr8240's Avatar
Thought it could have been running a little lean and hotter ambient temps helped??...
Old 22-01-2007, 04:32 PM   #7
FS5
thanks for the input,next time i'm at willowbank i'll let it cool off and see what happens.
Old 22-01-2007, 04:50 PM   #8
Stav
Smile
Stav's Avatar
You will easily have another 6-10rwkws when cool compared to hot
Old 27-01-2007, 11:58 PM   #9
tel408
Your converter do this!
tel408's Avatar
Might be an interesting exercise to do a pass at different water tempeture's, to see where it will make it's most power, consistantly. Some motor's will make more power at a lower temp range say around the150 mark, some at 180. Every motor is different.
Visit my Telstar drag car here
www.xr8ute.com/friends_telstar.php
A1 Performance Torque Converters
0403534803
tel408 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
